andymoose
(Andrine)
January 18, 2019, 6:36pm
1
I am trying to setup the git plugin but I get an error. I am following this youtube tutorial , but after 2:44 I get
root@ubuntu~# caddy
Activating privacy features… done.
From https://github.com/Name/MyRepoAame
On my server the structure is:
I have a directory called myreponame with an index.html and the Caddyfile. The Caddyfile contains:
https://myWebPage.com
git github.com/mygithubaccount/myrepo
root myreponame
When I type pwd I get /root, so I have tested to change the Caddyfile to:
root /root/myreponame
but I can the same error: 2019/01/18 18:20:18 listen tcp :443: bind: address already in use
Just shout out if I need to explain any further. I appreciate the help I get.
andymoose
(Andrine)
January 18, 2019, 6:54pm
2
When I test with $ dig myhomepage.com I get
QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
This error means that Caddy tried to bind to port 443, but failed (because some other process is already using that port).
You can check which program it is with the command: netstat -tulpn | grep 443
andymoose
(Andrine)
January 19, 2019, 11:56am
4
Does not really tell me to much @Whitestrake
Looks like Caddy is already running in the background (with the process ID 31069). You won’t be able to run two Caddies on the same ports, so you’ll want to take down that one before starting it up again.
If it’s not running as a service, you can run the command kill -SIGTERM 31069 to have the system signal the other Caddy to shut down gracefully.
andymoose
(Andrine)
January 19, 2019, 1:08pm
6
You know everything, thanks
andymoose
(Andrine)
January 19, 2019, 1:49pm
7
And now I have a problem with webhooks…
This is now my Caddyfile:
https://MyUrl.com
git github.com/GithubName/RepoName . {
hook /_webhook some-keys
root DirectoryWithFiles
Here is screenshot from Github:
And I get Last delivery was not succesfull
“could not connect to server”
Is the server running?
Can you access that URL in your browser?
andymoose
(Andrine)
January 19, 2019, 2:00pm
9
Works now. Haha, that was a blunder. Thanks!
system
(system)
Closed
April 19, 2019, 2:00pm
10
