1. The problem I’m having is a file access issue:
You can access the website via “curl -vL https://www.duelify.com”, and the access seems ok. But when you load it via browser the index.html isn’t showing.
http.handlers.file_server no index file in directory {"path": "/var/www/html", "index_filenames": ["index.html", "index.txt"]}
2024/03/21 10:20:59.639 DEBUG events event {"name": "tls_get_certificate", "id": "dec990a2-1fe0-44ba-a78b-03c3ac088848", "origin": "tls", "data": {"client_hello":{"CipherSuites":[19018,4865,4866,4867,49196,49195,52393,49200,49199,52392,49162,49161,49172,49171,157,156,53,47,49160,49170,10],"ServerName":"www.duelify.com","SupportedCurves":[6682,29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,515,2053,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[23130,772,771,770,769],"RemoteAddr":{"IP":"152.37.xx.xxx","Port":29901,"Zone":""},"LocalAddr":{"IP":"91.107.229.214","Port":443,"Zone":""}}}}
2024/03/21 10:20:59.641 DEBUG tls.handshake no matching certificates and no custom selection logic {"identifier": "www.duelify.com"}
2024/03/21 10:20:59.641 DEBUG tls.handshake choosing certificate {"identifier": "*.duelify.com", "num_choices": 1}
2024/03/21 10:20:59.642 DEBUG tls.handshake default certificate selection results {"identifier": "*.duelify.com", "subjects": ["*.duelify.com"], "managed": true, "issuer_key": "acme-v02.api.letsencrypt.org-directory", "hash": "fea6e45fb3072ee7e2f1547f6c3bd8e374134164340e0a2ed51c69ad6304bb83"}
2024/03/21 10:20:59.642 DEBUG tls.handshake matched certificate in cache {"remote_ip": "152.37.xx.xxx", "remote_port": "29901", "subjects": ["*.duelify.com"], "managed": true, "expiration": "2024/06/19 08:28:13.000", "hash": "fea6e45fb3072ee7e2f1547f6c3bd8e374134164340e0a2ed51c69ad6304bb83"}
2024/03/21 10:20:59.678 DEBUG http.handlers.file_server sanitized path join {"site_root": "/var/www/html", "request_path": "/", "result": "/var/www/html"}
2024/03/21 10:20:59.678 DEBUG http.handlers.file_server no index file in directory {"path": "/var/www/html", "index_filenames": ["index.html", "index.txt"]}
2024/03/21 10:20:59.679 DEBUG http.log.error {id=decjqua29} fileserver.(*FileServer).notFound (staticfiles.go:629): HTTP 404 {"request": {"remote_ip": "152.37.xx.xxx", "remote_port": "29901", "client_ip": "152.37.xx.xxx", "proto": "HTTP/2.0", "method": "GET", "host": "www.duelify.com", "uri": "/", "headers": {"Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"], "Sec-Fetch-Site": ["none"], "Accept-Encoding": ["gzip, deflate, br"], "Upgrade-Insecure-Requests": ["1"], "Sec-Fetch-Mode": ["navigate"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.4 Safari/605.1.15"], "Accept-Language": ["en-GB,en;q=0.9"], "Sec-Fetch-Dest": ["document"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "www.duelify.com"}}, "duration": 0.00106816, "status": 404, "err_id": "decjqua29", "err_trace": "fileserver.(*FileServer).notFound (staticfiles.go:629)"}
But as you can see the index.html is clearly there. Could it be an access issue?
At first the index.html was 501, staff. Then I changed it to caddy:caddy and it is still not working.
root@DE-NUR-X-P-1:/var/www/html# ls -lt
total 624
-rw-r--r-- 1 caddy caddy 4055 Mar 20 10:56 index.html
-rw-r--r-- 1 501 staff 144568 Nov 30 17:13 4.jpg
-rw-r--r-- 1 501 staff 108383 Nov 30 17:13 3.jpg
-rw-r--r-- 1 501 staff 166949 Nov 30 17:13 2.jpg
-rw-r--r-- 1 501 staff 205044 Nov 30 17:12 1.jpg
sudo groupadd --system caddy
sudo useradd --system \
--gid caddy \
--create-home \
--home-dir /var/lib/caddy \
--shell /usr/sbin/nologin \
--comment "Caddy web server" \
caddy
tar -zxvf caddy-linux-amd64.tar.gz
sudo mv caddy /usr/bin/
sudo chown caddy:caddy /usr/bin/caddy
sudo chmod 700 /usr/bin/caddy
sudo mkdir /etc/caddy
sudo mkdir /var/log/caddy
sudo chown caddy:caddy /var/log/caddy
Debian 12, amd64, systemd
Running it as Daemon (systemd) doesn’t work. But if I run this manually as root as shown below - without changing anything - then it works, this seems to be a file permission problem. But it doesn’t make sense.
systemctl stop caddy
export CLOUDFLARE_API_TOKEN="xxx"
/usr/bin/caddy run --environ --config /etc/caddy/caddy.json
echo "[Unit]
Type=notify
Environment=CLOUDFLARE_API_TOKEN=${CLOUDFLARE_API_TOKEN}
ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/caddy.json
ExecReload=/usr/bin/caddy reload --config /etc/caddy/caddy.json --force
" | sudo tee /etc/systemd/system/caddy.service >/dev/null
"admin": {
"disabled": true,
"config": {
"persist": false
"logging": {
"logs": {
"default": {
"writer": {
"output": "file",
"filename": "/var/log/caddy/default.log"
"encoder": {
"format": "console"
"level": "DEBUG"
"apps": {
"http": {
"servers": {
"srvh1": {
"listen": [":80"],
"routes": [{
"handle": [{
"handler": "static_response",
"headers": {
"Location": ["https://{http.request.host}{http.request.uri}"]
"status_code": 301
"protocols": ["h1"]
"srvh2": {
"listen": ["127.0.0.1:7443"],
"listener_wrappers": [{
"wrapper": "proxy_protocol"
"wrapper": "tls"
"wrapper": "trojan"
"routes": [{
"match": [{
"path": ["/7d8d47bb"],
"header": {
"Connection": ["*Upgrade*"],
"Upgrade": ["websocket"]
"handle": [{
"handler": "reverse_proxy",
"upstreams": [{
"dial": "127.0.0.1:2001"
"match": [{
"path": ["/521029e5"]
"handle": [{
"transport": {
"protocol": "http",
"versions": ["h2c","2"]
"upstreams": [{
"dial": "127.0.0.1:2005"
"match": [{
"protocol": "grpc",
"path": ["/SALdGZ9k/*"]
"handle": [{
"transport": {
"protocol": "http",
"upstreams": [{
"dial": "127.0.0.1:2011"
"headers": {
"request": {
"set": {
"X-Real-IP": ["{http.vars.client_ip}"]
"handle": [{
"handler": "forward_proxy",
"auth_user_deprecated": "user",
"auth_pass_deprecated": "pass",
"hide_ip": true,
"hide_via": true,
"probe_resistance": {}
"handle": [{
"handler": "trojan",
"connect_method": true,
"websocket": true
"handle": [{
"handler": "headers",
"response": {
"set": {
"Strict-Transport-Security": ["max-age=31536000; includeSubDomains; preload"]
"handler": "file_server",
"root": "/var/www/html"
"tls_connection_policies": [{
"match": {
"sni": ["83e9c4f0.duelify.com"]
"protocol_min": "tls1.2",
"protocol_max": "tls1.2",
"cipher_suites": ["TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256"],
"curves": ["secp521r1","secp384r1","secp256r1"]
"match": {
"sni": ["www.duelify.com","0755747c.duelify.com"]
"cipher_suites": ["TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384","TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256","TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256"],
"curves": ["x25519","secp521r1","secp384r1","secp256r1"]
"trusted_proxies": {
"source": "cloudflare",
"interval": "12h",
"timeout": "15s"
"protocols": ["h1","h2"]
"trojan": {
"proxy": {
"proxy": "no_proxy"
"upstream": {
"upstream": "memory"
"users": ["diy443"]
"tls": {
"certificates": {
"automate": [
"duelify.com",
"*.duelify.com"
"automation": {
"policies": [
"issuers": [
"module": "acme",
"email": "info@vc.com",
"challenges": {
"dns": {
"provider": {
"name": "cloudflare",
"api_token": "{env.CLOUDFLARE_API_TOKEN}"
"module": "zerossl",
"challenges": {
"dns": {
"provider": {
