Problems with dynamic upstreams using DNS A records
I am trying to use Caddy as a reverse proxy with dynamic upstreams. The upstreams are supposed to be resolved via DNS A records.
The upstream servers and caddy are in a docker network.
This seems to “kinda” work. I can reach the backend from the frontend however the health_check does not seem to work. No matter what I make the heath check return the upstreams are still reachable. There are also no health check related messages in the log.
If I stop all upstream servers I get the following message:
{"level":"error","ts":1679922847.3636703,"logger":"http.handlers.reverse_proxy","msg":"failed getting dynamic upstreams; falling back to static upstreams","error":"lookup react-gateway on 127.0.0.11:53: server misbehaving"}
Which makes sense.
Also querying the API at reverse_proxy/upstreams returns an empty list. (see next point)
curl "http://localhost:2019/reverse_proxy/upstreams"
Official Caddy docker image caddy:2.6
  default:
    driver: bridge
  frontend:
  backend:
  react-gateway:
    image: registry.example.com/react-gateway
    hostname: react-gateway
      frontend:
      backend:
    deploy:
      replicas: 4
  react-client:
    image: registry.example.com/react-client:caddy
      - target: 80
        published: 80
        protocol: tcp
        mode: host
      - target: 443
        published: 443
        protocol: tcp
        mode: host
      frontend:
      - ./caddy_data:/data
example.com {
	push
	encode zstd gzip
		# Hide "Server: Caddy"
		-Server
		Content-Security-Policy default-src 'self'
		X-XSS-Protection 1; mode=block
		Strict-Transport-Security max-age=31536000; includeSubDomains; preload
		X-Frame-Options DENY
		X-Frame-Options: SAMEORIGIN
		Content-Security-Policy upgrade-insecure-requests
		Feature-Policy "accelerometer 'none'; ambient-light-sensor 'none'; autoplay 'self'; camera 'none'; encrypted-media 'none'; fullscreen 'self'; geolocation 'none'; gyroscope 'none'; magnetometer 'none'; microphone 'none'; midi 'none'; payment 'none'; picture-in-picture *; speaker 'none'; sync-xhr 'none'; usb 'none'; vr 'none'"
		output stdout
		format json
	handle /rest/* {
		reverse_proxy * {
			dynamic a {
				name react-gateway
				port 3001
				refresh 5s
				resolvers 127.0.0.11:53
			header_up X-Real-IP {remote}
			health_uri /rest/infrastructure/isHealthy # Backend health check path
			# health_port     80 # Default same as backend port
			health_interval 20s
			health_timeout 10s
			#health_status 200
			health_body healthy
		root * /var/www/html
		try_files {path} /index.html
The problem with active health checks + dynamic upstreams is that fetching the list of dynamic upstreams requires a request, since the dynamic upstreams interface takes the incoming request as input for maximum flexibility. Active health checks happen in the background, and aren’t triggered by a request, so technically there’s no known upstreams for active health checks to try.
This is mentioned in the docs, at the top of the dynamic upstreams section:
Same deal.
