OK, I’ve just discovered Where are certs stored under the default systemd setup? · Issue #3468 · caddyserver/caddy · GitHub, seems the certificates for v.1 were in /etc/ssl/caddy/
. But I don’t know how the /var/lib/caddy
directory came to exist, and why Caddy now wants to use /var/www/
as its home dir. Changing the owner of /var/lib/caddy
and all its contents to www-data
and restarting got me nowhere.
I guess I should live with Caddy running as user caddy
(which is not the Debian standard for web servers) and change the permissions of /var/www
instead … I’ll go and test this.
Been there, done that. One step further ahead, but not yet there: Running with user caddy
helped, Caddy can use /var/lib/caddy
as home dir again and is using the certificate. But I don’t get my home page in the browser, but only a completely blank page …
Maybe someone can read something useful from the logs (I can’t):
Jul 5 17:16:23 production systemd[1]: caddy.service: Succeeded.
Jul 5 17:16:23 production caddy[1971]: caddy.HomeDir=/var/lib/caddy
Jul 5 17:16:23 production caddy[1971]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jul 5 17:16:23 production caddy[1971]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jul 5 17:16:23 production caddy[1971]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jul 5 17:16:23 production caddy[1971]: runtime.GOOS=linux
Jul 5 17:16:23 production caddy[1971]: runtime.GOARCH=amd64
Jul 5 17:16:23 production caddy[1971]: runtime.Compiler=gc
Jul 5 17:16:23 production caddy[1971]: runtime.NumCPU=2
Jul 5 17:16:23 production caddy[1971]: runtime.GOMAXPROCS=2
Jul 5 17:16:23 production caddy[1971]: runtime.Version=go1.14.4
Jul 5 17:16:23 production caddy[1971]: os.Getwd=/
Jul 5 17:16:23 production caddy[1971]: LANG=C.UTF-8
Jul 5 17:16:23 production caddy[1971]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Jul 5 17:16:23 production caddy[1971]: HOME=/var/lib/caddy
Jul 5 17:16:23 production caddy[1971]: LOGNAME=caddy
Jul 5 17:16:23 production caddy[1971]: USER=caddy
Jul 5 17:16:23 production caddy[1971]: INVOCATION_ID=6d158c3fd3d74a1c9926b7836060cb62
Jul 5 17:16:23 production caddy[1971]: JOURNAL_STREAM=9:28953
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.4544854,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.477268,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["127.0.0.1:2019","localhost:2019","[::1]:2019"]}
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.4776592,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.4776986,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 5 17:16:23 production caddy[1971]: 2020/07/05 17:16:23 [INFO][cache:0xc000100540] Started certificate maintenance routine
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.4800642,"logger":"tls","msg":"cleaned up storage units"}
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.4802983,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["www.bobc.uni-bonn.de"]}
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.513183,"msg":"autosaved config","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jul 5 17:16:23 production caddy[1971]: {"level":"info","ts":1593962183.5132167,"msg":"serving initial configuration"}
Jul 5 17:16:39 production caddy[1971]: {"level":"info","ts":1593962199.81341,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/index.php?action=list_LISTSOMERESOURCES_CORE&method=keywordProcess&id=1510&catId=1&type=lastMulti","proto":"HTTP/1.1","remote_addr":"77.88.9.131:39016","host":"www.bobc.uni-bonn.de","headers":{"Accept-Encoding":["gzip,deflate"],"Accept":["*/*"],"Connection":["Keep-Alive"],"User-Agent":["Mozilla/5.0 (compatible; YandexBot/3.0; +http://yandex.com/bots)"],"From":["support@search.yandex.ru"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"77.88.9.131 - - [05/Jul/2020:17:16:39 +0200] \"GET /index.php?action=list_LISTSOMERESOURCES_CORE&method=keywordProcess&id=1510&catId=1&type=lastMulti HTTP/1.1\" 0 0","duration":0.000032674,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:16:44 production caddy[1971]: {"level":"info","ts":1593962204.8834617,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59213","host":"www.bobc.uni-bonn.de","headers":{"Dnt":["1"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Mode":["cors"],"Sec-Fetch-Dest":["image"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":["PHPSESSID=tjacpvvnagf5dvgqahfpderh1u; rl_anonymous_id=%228e3a0f5c-d1d2-4137-b346-a23bc6c852e2%22; rl_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; rl_trait=%7B%7D; ajs_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; ajs_anonymous_id=%2200000000000000000000000000%22"],"Origin":["chrome-extension://mpognobbkildjkofajifpdfhcoklimli"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.119 Safari/537.36"],"Accept":["image/webp,image/apng,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["none"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:16:44 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000033269,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:16:47 production caddy[1971]: {"level":"info","ts":1593962207.5716755,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59213","host":"www.bobc.uni-bonn.de","headers":{"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":["PHPSESSID=tjacpvvnagf5dvgqahfpderh1u; rl_anonymous_id=%228e3a0f5c-d1d2-4137-b346-a23bc6c852e2%22; rl_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; rl_trait=%7B%7D; ajs_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; ajs_anonymous_id=%2200000000000000000000000000%22"],"Cache-Control":["max-age=0"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.119 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Mode":["navigate"],"Dnt":["1"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:16:47 +0200] \"GET / HTTP/2.0\" 0 0","duration":0.000076343,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:16:47 production caddy[1971]: {"level":"info","ts":1593962207.707989,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59213","host":"www.bobc.uni-bonn.de","headers":{"Accept":["image/webp,image/apng,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["none"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":["PHPSESSID=tjacpvvnagf5dvgqahfpderh1u; rl_anonymous_id=%228e3a0f5c-d1d2-4137-b346-a23bc6c852e2%22; rl_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; rl_trait=%7B%7D; ajs_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; ajs_anonymous_id=%2200000000000000000000000000%22"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.119 Safari/537.36"],"Dnt":["1"],"Sec-Fetch-Mode":["cors"],"Sec-Fetch-Dest":["image"],"Accept-Encoding":["gzip, deflate, br"],"Origin":["chrome-extension://mpognobbkildjkofajifpdfhcoklimli"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:16:47 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000023206,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:16:47 production caddy[1971]: {"level":"info","ts":1593962207.712034,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59213","host":"www.bobc.uni-bonn.de","headers":{"Sec-Fetch-Dest":["image"],"Cookie":["PHPSESSID=tjacpvvnagf5dvgqahfpderh1u; rl_anonymous_id=%228e3a0f5c-d1d2-4137-b346-a23bc6c852e2%22; rl_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; rl_trait=%7B%7D; ajs_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; ajs_anonymous_id=%2200000000000000000000000000%22"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.119 Safari/537.36"],"Cache-Control":["no-cache"],"Dnt":["1"],"Accept":["image/webp,image/apng,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["no-cors"],"Referer":["https://www.bobc.uni-bonn.de/"],"Accept-Encoding":["gzip, deflate, br"],"Pragma":["no-cache"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:16:47 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000020667,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:16:47 production caddy[1971]: {"level":"info","ts":1593962207.7742472,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59213","host":"www.bobc.uni-bonn.de","headers":{"Accept-Encoding":["gzip, deflate, br"],"Cookie":["PHPSESSID=tjacpvvnagf5dvgqahfpderh1u; rl_anonymous_id=%228e3a0f5c-d1d2-4137-b346-a23bc6c852e2%22; rl_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; rl_trait=%7B%7D; ajs_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; ajs_anonymous_id=%2200000000000000000000000000%22"],"Origin":["chrome-extension://mpognobbkildjkofajifpdfhcoklimli"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.119 Safari/537.36"],"Accept":["image/webp,image/apng,image/*,*/*;q=0.8"],"Sec-Fetch-Mode":["cors"],"Sec-Fetch-Dest":["image"],"Dnt":["1"],"Sec-Fetch-Site":["none"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:16:47 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000022044,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:16:52 production caddy[1971]: {"level":"info","ts":1593962212.7483509,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59213","host":"www.bobc.uni-bonn.de","headers":{"Sec-Fetch-Mode":["cors"],"Sec-Fetch-Dest":["image"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.119 Safari/537.36"],"Dnt":["1"],"Accept":["image/webp,image/apng,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["none"],"Origin":["chrome-extension://mpognobbkildjkofajifpdfhcoklimli"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":["PHPSESSID=tjacpvvnagf5dvgqahfpderh1u; rl_anonymous_id=%228e3a0f5c-d1d2-4137-b346-a23bc6c852e2%22; rl_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; rl_trait=%7B%7D; ajs_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; ajs_anonymous_id=%2200000000000000000000000000%22"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:16:52 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000035183,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:00 production caddy[1971]: {"level":"info","ts":1593962220.6961613,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/index.php","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59238","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/605.1.15 (KHTML, like Gecko)"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:00 +0200] \"GET /index.php HTTP/2.0\" 0 0","duration":0.000033069,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:00 production caddy[1971]: {"level":"info","ts":1593962220.811581,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon-precomposed.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:00 +0200] \"GET /apple-touch-icon-precomposed.png HTTP/2.0\" 0 0","duration":0.000024414,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:00 production caddy[1971]: {"level":"info","ts":1593962220.8583713,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:00 +0200] \"GET /apple-touch-icon.png HTTP/2.0\" 0 0","duration":0.000031957,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:00 production caddy[1971]: {"level":"info","ts":1593962220.8849359,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:00 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000022321,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:00 production caddy[1971]: {"level":"info","ts":1593962220.910623,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon-precomposed.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:00 +0200] \"GET /apple-touch-icon-precomposed.png HTTP/2.0\" 0 0","duration":0.000023966,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:00 production caddy[1971]: {"level":"info","ts":1593962220.9554741,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:00 +0200] \"GET /apple-touch-icon.png HTTP/2.0\" 0 0","duration":0.000027064,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:00 production caddy[1971]: {"level":"info","ts":1593962220.9859576,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:00 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000021007,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:01 production caddy[1971]: {"level":"info","ts":1593962221.0162249,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/index.php","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59238","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Mozilla/5.0 (iPhone; CPU iPhone OS 13_1_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.0.1 Mobile/15E148 Safari/604.1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:01 +0200] \"GET /index.php HTTP/2.0\" 0 0","duration":0.000020942,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:01 production caddy[1971]: {"level":"info","ts":1593962221.0451522,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon-precomposed.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:01 +0200] \"GET /apple-touch-icon-precomposed.png HTTP/2.0\" 0 0","duration":0.000021689,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:01 production caddy[1971]: {"level":"info","ts":1593962221.072854,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:01 +0200] \"GET /apple-touch-icon.png HTTP/2.0\" 0 0","duration":0.00002086,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:01 production caddy[1971]: {"level":"info","ts":1593962221.0965755,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:01 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000022279,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:01 production caddy[1971]: {"level":"info","ts":1593962221.1500337,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon-precomposed.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:01 +0200] \"GET /apple-touch-icon-precomposed.png HTTP/2.0\" 0 0","duration":0.000021264,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:01 production caddy[1971]: {"level":"info","ts":1593962221.1769783,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:01 +0200] \"GET /apple-touch-icon.png HTTP/2.0\" 0 0","duration":0.000020447,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:01 production caddy[1971]: {"level":"info","ts":1593962221.2078073,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:01 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000020657,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:08 production caddy[1971]: {"level":"info","ts":1593962228.6482642,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59272","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.1.1 Safari/605.1.15"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:08 +0200] \"GET / HTTP/2.0\" 0 0","duration":0.000032341,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:08 production caddy[1971]: {"level":"info","ts":1593962228.692627,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon-precomposed.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:08 +0200] \"GET /apple-touch-icon-precomposed.png HTTP/2.0\" 0 0","duration":0.000021662,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:08 production caddy[1971]: {"level":"info","ts":1593962228.750223,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/apple-touch-icon.png","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59240","host":"www.bobc.uni-bonn.de","headers":{"User-Agent":["Safari/15609.2.9.1.2 CFNetwork/1126 Darwin/19.5.0 (x86_64)"],"Accept":["*/*"],"Accept-Language":["de-de"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:08 +0200] \"GET /apple-touch-icon.png HTTP/2.0\" 0 0","duration":0.000023147,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Jul 5 17:17:17 production caddy[1971]: {"level":"info","ts":1593962237.4127197,"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/2.0","remote_addr":"131.220.247.130:59213","host":"www.bobc.uni-bonn.de","headers":{"Cookie":["PHPSESSID=tjacpvvnagf5dvgqahfpderh1u; rl_anonymous_id=%228e3a0f5c-d1d2-4137-b346-a23bc6c852e2%22; rl_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; rl_trait=%7B%7D; ajs_user_id=%22jqogkp4mub8htfhjsuup7befcc%22; ajs_anonymous_id=%2200000000000000000000000000%22"],"Dnt":["1"],"Sec-Fetch-Site":["none"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Dest":["image"],"Origin":["chrome-extension://mpognobbkildjkofajifpdfhcoklimli"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.119 Safari/537.36"],"Accept":["image/webp,image/apng,image/*,*/*;q=0.8"],"Sec-Fetch-Mode":["cors"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"www.bobc.uni-bonn.de"}},"common_log":"131.220.247.130 - - [05/Jul/2020:17:17:17 +0200] \"GET /favicon.ico HTTP/2.0\" 0 0","duration":0.000034891,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
I’ll go back to v.1 for now
