What up B, this is my first post here and I’ll continue posting.
I’m trying to run a script in a different folder. When I do so, Caddy either returns a file not found, firefox returns a file not found, or it runs but not correctly, depending on the set up.
Currently, this is what I have:
site {
root folder
cgi {
match /*.cgi
exec {.}/{match}
cgi /*/upload.cgi {.}/{match}
What’s happening with the second script is it runs, but not in the folder it’s in. When I try creating a new site though, it runs partially (it’s running at the same time as the other):
CGI does not change the script’s working directory. If you need to do that, it should be done within your script.
Say Caddy’s default working directory is /caddy. A request for /foo.cgi will result in the first CGI instance attempting to run /caddy/foo.cgi. A request for /bar/upload.cgi will result in the second CGI instance attempting to run /caddy/bar/upload.cgi. And, for the site/new example, a request for /upload.cgi will result in the execution of /upload.cgi.
