I’v got two dockerized services (frontend service and database service) running on the same server. Currently, only the frontend service can be accessed with HTTPS. Here’s its Caddyfile:
As you may have guessed, this fails. I know just a little about web server configuration and HTTPS, so maybe this makes no sense in the first place. My thoughts why this won’t work:
Host port can’t be the same as the proxy port
With HTTPS, host names of both services can’t be the same, regardless of different ports.
But I am not sure about this. Further, a limitation applies to my situation:
Because many other services are already using subdomain.example.com:8086 URL, changing this URL whatsoever to make it work should be considered a last resort, as this would require a lot of work reconfiguring those services.
Long story short: serving two services running on the same server but different ports using HTTPS.
What am I doing wrong? And what’s the way to make it work (if there’s any in this particular situation)?
There’s a lot of useful info we’re missing - are you using Docker (with Compose)? What’s Caddy’s log saying when it fails?
Try transparent (spelling).
Receiving a request on port 8086 on the host and proxying to another IP address on the same port shouldn’t be an issue, but it depends on the (Docker?) configuration.
Are there other services on the same Caddy host that are trying to use the same URL and port?
Oops, forgot to fix that before posting. I already fixed it in the actual Caddyfile, and the problem remains.
No, only services running on hosts other than Caddy are using the URL subdomain.example.com:8086
I continued investigating, and things became more clear to me. Requests to subdomain.example.com:8086 will fail with ERR_INVALID_HTTP_RESPONSE (using Chrome), but using explicitly https:subdomain.example.com:8086 will succeed. This probably makes sense (as the latter is defined exactly the same in the Caddyfile) , that’s not the behavior I like to see . Any HTTP request on port 8086 should redirect to https:subdomain.example.com:8086
You’re on point with that one - you’ve instructed Caddy to only respond to https requests here. You can remove the https:// from the 8086 vhost and let Caddy’s automatic redirection kick in, or add another block like the following untested example:
Just tested it, but unfortunately it didn’t work. I got the same ERR_INVALID_HTTP_RESPONSE in Chrome. Caddy didn’t log any strange behavior, other than missing a http://subdomain.example.com:8086 entry what I had expected (assuming Caddy’s automatic redirection behavior):
Whoops! Damn, that’s me being an idiot, total rookie mistake. Of course you can’t have HTTP(,S) on the same port, same reason standard HTTP is port 80 and HTTPS is port 443. Caddy’s automatic HTTPS wouldn’t have done anything on nonstandard ports anyway, no idea why I suggested it.
In short I think you’re up the creek. Using HTTPS on a nonstandard port you’ll need to specify both scheme and port number for all connecting services, you will not be able to rely on Caddy upgrading HTTP(,S) on the same port.
Assuming your services are redirect friendly anyway, though, you can just open the HTTPS on another port (8087 or 8443 perhaps) and redir from http::8086 → https::8443, which is equivalent to what regular automatic HTTPS does anyway.
