1. Output of caddy version:
docker version
image: "caddy:2.6.2-alpine"
docker compose
Paste command here.
version: '3.3'
env_file:
- .env
- ./domen:/usr/share/caddy/domen:ro
- ./Caddyfile:/etc/caddy/Caddyfile # configuration
- caddy-config:/config # configuration autosaves
- caddy-data:/data # saving certificates
- app-network
depends_on:
- app
#PHP Service
app:
build:
context: .
dockerfile: Dockerfile
# image: digitalocean.com/php
container_name: app
tty: true
SERVICE_NAME: app
SERVICE_TAGS: dev
# working_dir: /var/www
- ./domen:/var/www/domen
- ./php/local.ini:/usr/local/etc/php/conf.d/local.ini
- app-network
#MySQL Service
db:
image: percona:5.7.35
container_name: db
tty: true
#ports:
# - "3306:3306"
MYSQL_DATABASE: laravel
MYSQL_ROOT_PASSWORD: your_mysql_root_password
SERVICE_TAGS: dev
SERVICE_NAME: mysql
- dbdata:/var/lib/mysql/
- ./mysql/my.cnf:/etc/mysql/my.cnf
- app-network
command: --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci --sql_mode="STRICT_TRANS_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION"
#Docker Networks
app-network:
driver: bridge
#Volumes
dbdata:
driver: local
caddy-data:
caddy-config:
# See https://caddyserver.com/docs
# Email for Let's Encrypt expiration notices
email {$TLS_EMAIL}
# "www" redirect to "non-www" version
www.{$DOMAIN_NAME} {
redir https://{$DOMAIN_NAME}{uri}
{$DOMAIN_NAME} {
# HTTPS options:
header Strict-Transport-Security max-age=31536000;
# Removing some headers for improved security:
header -Server
# Serving dynamic requests:
root * /var/www/{$DOMAIN_NAME}
php_fastcgi app:9000 {
read_timeout 3s
# Allows to use `.gz` files when available:
# Logs:
output stdout
caddy sends to fastcgi only a request of the form
log fastcgi:
app | 172.19.0.4 - 01/Nov/2022:15:06:41 +0000 "GET /index.php" 301
app | 172.19.0.4 - 01/Nov/2022:15:06:41 +0000 "GET /index.php" 200
I need it to send a rout
app | 172.19.0.4 - 01/Nov/2022:16:20:12 +0000 "GET /support/oprosy/" 200
path, are virtual, there are no folders
{$DOMAIN_NAME} {
# HTTPS options:
header -Server
root * /usr/share/caddy/{$DOMAIN_NAME}
# @canonicalPath {
# file {
# try_files {path}/index.php
# not {
# path */
@phpFiles {
path *.php
route {
# redir @canonicalPath {path}/ 308
try_files {path} {path}/index.php index.php
reverse_proxy @phpFiles {
to app:9000
transport fastcgi {
split .php
root /var/www/{$DOMAIN_NAME}
# Logs:
output stdout
Working nginx config:
server {
server_name {$DOMAIN_NAME};
root /var/www/{$DOMAIN_NAME}/;
index index.php;
access_log /var/www/umi.access.log;
error_log /var/www/umi.error.log warn;
location @index {
fastcgi_pass app:9000;
fastcgi_read_timeout 3600;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root/index.php;
fastcgi_param QUERY_STRING path=$full_path&$args;
fastcgi_param AUTHORIZATION $http_authorization;
location ~* ^/(developerTools|errors|libs|smt|cache|xmldb|static|packages)\/.*$ {
return 403;
location ~* (config\.ini|install\.ini|install\.log|umi\.nginx\.conf|(packer|dbview)\.php|composer\.umi\.(lock|json))$ {
return 403;
location ~* "/(sitemap[\d]{0,}\.xml|robots\.txt|favicon\.ico|sitemap-images[\d]{0,}\.xml)$" {
try_files $uri $uri/ @index;
location ~* ^/(ulang|autothumbs)/.*$ {
location ~* ^/*(?<full_path>.*\.(json|xml))$ {
expires 1d;
access_log off;
try_files $uri @index;
location ~* \.(bmp|css|doc|eot|flv|gif|htm|html|ico|jpe?g|js|otf|map|png|svg|tiff|ttf|twig|txt|webp|woff|woff2)$ {
expires 1d;
access_log off;
try_files $uri =404;
location ~ \.mp4$ {
mp4;
mp4_buffer_size 1m;
mp4_max_buffer_size 5m;
location ~ ^/(index|dummy|smu/installer|autothumbs|captcha|counter|cron|go-out|license_restore|save_domain_keycode|session|static_banner|updater)\.php$ {
location ~ ^/(umi_smt|install|installer)\.php$ {
fastcgi_param SCRIPT_FILENAME $document_root/$fastcgi_script_name;
location ~ ^/*(?<full_path>.*) {
try_files /sys-temp/static-cache/$host/$uri/index.html @index;
location ~ \.(php[2-5]?|cgi|pl|fcgi|fpl|phtm|phtml|shtml|asp|jsp|twig|tpl|xslt?|git|svn|htaccess|htaccess_old|htpasswd|gitignore|gitkeep|ini|log|conf|md|sql|lock|umi\.json)$ {
return 403;
# listen 80;
# listen [::]:80 ipv6only=on;
listen 443 ssl http2; # managed by Certbot
listen [::]:443 ipv6only=on http2;
ssl_certificate /etc/letsencrypt/live/{$DOMAIN_NAME}/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/{$DOMAIN_NAME}/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
location ~ /.well-known/acme-challenge {
allow all;
root /var/www/{$DOMAIN_NAME};
if ($host = {$DOMAIN_NAME}) {
return 301 https://{$DOMAIN_NAME}$request_uri;
} # managed by Certbot
return 301 https://$host$request_uri;
listen 80;
return 404; # managed by Certbot
