I don’t know what I’m doing. I have a huge problem to get Caddy working. I want to use a subdomain of my DynDNS address to access a podman container. The container itself is running fine and I can access it from the local network without a problem. But Caddy fails. I can’t even see the sub domain.
I think I fail at DNS and the DNS-01 challenge and how to set it all up. Even though 80 and 443 are forwarded to the correct machine and my domain has the correct IP addresses.
I tried to read tutorials but I’m now at point where all text feel the same.
So my questions are:
- How do I get my system running, so that the subdomains are working?
- What else do I need to get this running and how do I set up?
- Do I need to move my DNS for my domain/host to another provider to make this work? (Currently I use dynv6 and I need IPv6 to work)
Sep 12 17:26:02 random caddy[554]: {"level":"error","ts":1789226762.9128492,"logger":"http.acme_client","msg":"challenge failed","identifier":"music.random.teha.be","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:dns","title":"","detail":"no valid A records found for music.random.teha.be; no valid AAAA records found for music.random.teha.be","instance":"","subproblems":null}}
Sep 12 17:26:02 random caddy[554]: {"level":"error","ts":1789226762.9129524,"logger":"http.acme_client","msg":"validating authorization","identifier":"music.random.teha.be","problem":{"type":"urn:ietf:params:acme:error:dns","title":"","detail":"no valid A records found for music.random.teha.be; no valid AAAA records found for music.random.teha.be","instance":"","subproblems":null},"order":"https://acme-v02.api.letsencrypt.org/acme/order/3739970206/556525800476","attempt":1,"max_attempts":3}
pacman and AUR, rand with systemd, currently build and installed with layer4 plugin
Arch Linux, systemd, Caddy runs directly on the system.
sudo systemctl start caddy.service (did not change any of those.)
N/A
music.random.teha.be {
reverse_proxy * localhost:4533 {
header_up X-Forwarded-For {http.request.remote}
header_up X-Real-IP {http.reverse_proxy.upstream.port}
Type here
