When I try to reload Caddy to update the Caddyfile I use the following:
sudo caddy reload --config /etc/caddy/Caddyfile
The output I receive is:
2024/05/09 12:15:46.313 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
I have no idea what this means.
I don’t remember how I installed Caddy it has been months since I installed it.
# domain name.
admin 0.0.0.0:2020
acme_dns godaddy
nc.sceptic.au: {
tls internal
reverse_proxy localhost:11000
sonarr.sceptic.au {
tls internal
reverse_proxy 192.168.50.242:8989
homepage.sceptic.au {
tls internal
reverse_proxy localhost:3000
overseerr.sceptic.au {
tls internal
reverse_proxy localhost:5055
maintainerr.sceptic.au {
tls internal
reverse_proxy localhost:6246
radarr.sceptic.au {
tls internal
reverse_proxy localhost:7878
readarr.sceptic.au {
tls internal
reverse_proxy localhost:8787
lidarr.sceptic.au {
tls internal
reverse_proxy localhost:8686
sabnzbd.sceptic.au {
tls internal
reverse_proxy localhost:8089
prowlarr.sceptic.au {
tls internal
reverse_proxy localhost:9696
https://audio.sceptic.au:443 {
tls internal
reverse_proxy localhost:13378
tautulli.sceptic.au {
tls internal
reverse_proxy localhost:8181
paperless.sceptic.au {
tls internal
reverse_proxy localhost:8003
actual.sceptic.au {
tls internal
reverse_proxy localhost:5006
freshrss.sceptic.au {
tls internal
reverse_proxy localhost:8282
immich.sceptic.au {
tls internal
reverse_proxy localhost:2283
dozzle.sceptic.au {
tls internal
reverse_proxy localhost:8888
ukuma.sceptic.au {
tls internal
reverse_proxy localhost:3001
filebrowser.sceptic.au {
tls internal
reverse_proxy localhost:8383
dockge.sceptic.au {
tls internal
reverse_proxy localhost:5001
linkding.sceptic.au {
tls internal
reverse_proxy localhost:9090
change.sceptic.au {
tls internal
reverse_proxy localhost:5000
duplicati.sceptic.au {
tls internal
reverse_proxy localhost:8200
stirlingpdf.sceptic.au {
tls internal
reverse_proxy localhost:8088
nomie.sceptic.au {
reverse_proxy 192.168.50.242:5000
nomie-db.sceptic.au {
reverse_proxy 192.168.50.242:5984
Ubuntu 23.10
Docker 26.1.1
