Dear community,
I need your support with a security question regarding host header injection. As far as I can tell, the default behaviour of caddy is not optional, but let me explain.
My configuration
Imagine this docker-compose.yml file:
image: caddy:2.8.4
- /opt/caddy:/data
and this Caddyfile:
142.132.160.129.nip.io {
respond "awesome."
The “normal” requests
http is redirected just fine
curl http://142.132.160.129.nip.io -I
HTTP/1.1 308 Permanent Redirect
Connection: close
Server: Caddy
Date: Mon, 14 Oct 2024 10:35:45 GMT
https is returning my content:
curl https://142.132.160.129.nip.io
awesome
Security concerns
My question is regarding host header injection. More info about it here: Skeleton Scribe: Practical HTTP Host header attacks. So let’s assume somebody is sending this request:
curl http://142.132.160.129.nip.io -I -H "Host: evil.com"
My attempts to solve that
I tried multiple things, but this is what turned out to work:
redir https://142.132.160.129.nip.io{uri}
:443 {
tls internal
respond "not ok..."
https://142.132.160.129.nip.io {
respond "awesome"
This prevents Caddy to redirect to any other site.
What I also tried
I tried for example inside my https:// block the following:
@correct_host host 142.132.160.129.nip.io
handle @correct_host {
respond "aweseome"
respond "Wrong host" 443
Unfortunately, this does not solved my problem. The inbuild redirect of caddy takes place before this blocks is executed.
My questions
What do you think about my observation? I know this still requires uses to click to a false link etc, but still I would like to avoid, that the server is so easily tricked with a new host value.
Is there a simpler way to achieve this?
