Prevent caddy from trying to manage certificates
Caddy is crashing trying to manage certificates for me. I already manage my certificates with certbot, and don’t want this behavior at all.
 Error: loading initial config: loading new config: http app module: start: finalizing automatic HTTPS: managing certificates for 1 domains: automate: manage [nmflight.com]: nmflight.com: caching certificate: open caddy/certificates/acme-v02.api.letsencrypt.org-directory/nmflight.com/nmflight.com.key: not a directory
Compiled via xcaddy
Running on Fedora Server 41
Running via a service. Running normally works fine
Description=Start Caddy
Type=forking
WorkingDirectory=/usr/local/bin/
ExecStart=/usr/local/bin/caddy start
nmflight.com
redir /jellyfin /jellyfin/
reverse_proxy /jellyfin/* 127.0.0.1:8096
I have seen this, but I honestly have no clue how to interpret it. There is nothing that explicitly states how to completely and totally disable all certificate related actions.
If you want to give Caddy the certificates that were procured by certbot, use the tls directive like
example.com {
    tls cert.pem key.pem
    # everything else goes here ...
If you want Caddy to serve everything without HTTPS at all, prepend the site address with http://, but why? Why use certbot? Caddy can manage it for you just fine and with one less component to break. It’s the best at this job.
Thank you! I was using certbot left over from some other projects, but I’ll switch over to using caddy
