Precise syntax for reverse_proxy
1. Caddy version (caddy version): v2.1.1 h1:X9k1+ehZPYYrSqBvf/ocUgdLSRIuiNiMo7CvyGUQKeA=
Raspian Buster on Raspberry Pi 4
It will use systemd but I have not made it that far yet, still just trying to get it to work manually.
# /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
After=network.target
# domain name.
# Letsencrypt staging environment
# https://acme-staging-v02.api.letsencrypt.org/directory
# root * /usr/share/caddy
# file_server
# php_fastcgi localhost:9000
   email greg@gregandeva.net
reverse_proxy www.gregandeva.net https://mongoliad.gregandeva.net
reverse_proxy gregandeva.duckdns.org:8123 http://hassos.gregandeva.net:8123
reverse_proxy hassos.gregandeva.net:8123 http://hassos.gregandeva.net:8123
What I am trying to do is figure out the precise syntax of a reverse_proxy directive. I have been struggling with this all day and tried so many different things that I cannot remember them all. So perhaps someone will be able to see from the above Caddyfile what I am trying to do and tell me what the proper syntax is.
Looks like it is trying to get a cert for the domain “reverse_proxy”? Clearly my syntax is incorrect.
2020/07/05 23:32:25.234 INFO    using adjacent Caddyfile
2020/07/05 23:32:25.241 INFO    admin   admin endpoint started  {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2020/07/05 23:32:25.242 INFO    http    server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS    {"server_name": "srv0", "https_port": 443}
2020/07/05 23:32:25.242 INFO    http    enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2020/07/05 17:32:25 [INFO][cache:0x3ccaa00] Started certificate maintenance routine
2020/07/05 23:32:25.251 INFO    tls     cleaned up storage units
2020/07/05 23:32:25.252 DEBUG   http    starting server loop    {"address": "[::]:443", "http3": false, "tls": true}
2020/07/05 23:32:25.253 DEBUG   http    starting server loop    {"address": "[::]:80", "http3": false, "tls": false}
2020/07/05 23:32:25.254 INFO    http    enabling automatic TLS certificate management   {"domains": ["mongoliad.gregandeva.net", "reverse_proxy", "www.gregandeva.net"]}
2020/07/05 17:32:25 [INFO][reverse_proxy] Obtain certificate; acquiring lock...
2020/07/05 17:32:25 [INFO][reverse_proxy] Obtain: Lock acquired; proceeding...
2020/07/05 23:32:25.262 INFO    autosaved config        {"file": "/root/.config/caddy/autosave.json"}
2020/07/05 23:32:25.263 INFO    serving initial configuration
2020/07/05 17:32:25 [INFO][reverse_proxy] Waiting on rate limiter...
2020/07/05 17:32:25 [INFO][reverse_proxy] Done waiting
2020/07/05 17:32:25 [INFO] [reverse_proxy] acme: Obtaining bundled SAN certificate given a CSR
2020/07/05 17:32:25 [ERROR] acme: error: 400 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rejectedIdentifier :: Error creating new order :: Cannot issue for "reverse_proxy": Domain name contains an invalid character, url:  (challenge=tls-alpn-01 remaining=[http-01])
2020/07/05 17:32:27 [INFO] [reverse_proxy] acme: Obtaining bundled SAN certificate given a CSR
2020/07/05 17:32:28 [ERROR] acme: error: 400 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rejectedIdentifier :: Error creating new order :: Cannot issue for "reverse_proxy": Domain name contains an invalid character, url:  (challenge=http-01 remaining=[])
2020/07/05 17:32:30 [ERROR] attempt 1: [reverse_proxy] Obtain: [reverse_proxy] acme: error: 400 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rejectedIdentifier :: Error creating new order :: Cannot issue for "reverse_proxy": Domain name contains an invalid character, url:  - retrying in 1m0s (4.749510931s/720h0m0s elapsed)...
2020/07/05 17:33:33 [INFO] acme: Registering account for greg@gregandeva.net
2020/07/05 17:33:34 [INFO] [reverse_proxy] acme: Obtaining bundled SAN certificate given a CSR
2020/07/05 17:33:34 [ERROR] acme: error: 400 :: POST :: https://acme-staging-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rejectedIdentifier :: Error creating new order :: Cannot issue for "reverse_proxy": Domain name contains an invalid character, url:  (challenge=tls-alpn-01 remaining=[http-01])
2020/07/05 17:33:36 [INFO] [reverse_proxy] acme: Obtaining bundled SAN certificate given a CSR
2020/07/05 17:33:36 [ERROR] acme: error: 400 :: POST :: https://acme-staging-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rejectedIdentifier :: Error creating new order :: Cannot issue for "reverse_proxy": Domain name contains an invalid character, url:  (challenge=http-01 remaining=[])
2020/07/05 17:33:38 [ERROR] attempt 2: [reverse_proxy] Obtain: [reverse_proxy] acme: error: 400 :: POST :: https://acme-staging-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rejectedIdentifier :: Error creating new order :: Cannot issue for "reverse_proxy": Domain name contains an invalid character, url:  - retrying in 2m0s (1m13.218004749s/720h0m0s elapsed)...
Here’s where I may run into trouble. I tried so many things I can’t tell you exactly what they were. But here’s a sample:
:443
reverse_proxy mongoliad.gregandeva.net
:8123
reverse_proxy http://hassos.gregandeva.net:8123
That fails to validate:
2020/07/05 23:50:26.058 INFO    using adjacent Caddyfile
validate: adapting config using caddyfile: Caddyfile:38: unrecognized directive: :8123
https://caddyserver.com/docs/caddyfile/directives/reverse_proxy
Thanks for any help.
–Greg
Welcome Greg,
Be sure to check out the structure of the Caddyfile (particularly the key points): Caddyfile Concepts — Caddy Documentation
That should give you a hint. :slight_smile: It should take you about 5 seconds to fix once you read it. Let me know how it goes.
You’re right, I have it working now. I spent many hours trying to get this to work, and I read through a lot of the documentation, other posts in this forum, etc., but I just never hit on that particular page. Thanks for the pointer.
–Greg
