I’m trying to reverse proxy my postgres image in docker so that i can interact with it within my NodeJS project. I’ve installed xCaddy with Layer4 but the documentation is too bloated and I’m not sure where to modify. Basically I just want to reverse proxy TCP the port 5432; which is postgres.
May 24 19:54:17 mwa1 caddy[8400]: Error: adapting config using caddyfile: Unexpected '{' on a new line; did you mean to place the '{' on the previous line?, at /etc/caddy/Caddyfile:41
May 24 19:54:17 mwa1 systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
May 24 19:54:17 mwa1 systemd[1]: caddy.service: Failed with result 'exit-code'.
May 24 19:54:17 mwa1 systemd[1]: Failed to start caddy.service - Caddy.
I’ve used caddy to quite some times and had no problem reverse proxy http, but this is my first time trying out TCP reverse proxy. I installed xcaddy and layer4 because i read it is used to reverse proxy TCP.
Ubuntu VPS
docker-compose.yml
mwa1-backend:
image: 'nrmnqdds/mwa-backend:v0.0.29'
- '3040:3040'
restart: always
- DATABASE_URL=old_supabase_url
- JWT_SECRET=secret
- RESEND_KEY=secret
postgres:
image: 'postgres:16'
- POSTGRES_USER=postgres
- POSTGRES_PASSWORD=password
- POSTGRES_DB=db-test
- "5432:5432"
restart: always
pg-admin:
image: 'dpage/pgadmin4:8'
- PGADMIN_DEFAULT_EMAIL=admin@admin.org
- PGADMIN_DEFAULT_PASSWORD=password
- PGADMIN_LISTEN_PORT=5050
- "5050:5050"
restart: always
Caddyfile:
api.mwa.mulhaq.org {
reverse_proxy localhost:3040
pgadmin.mulhaq.org {
reverse_proxy localhost:5050
"servers": {
"secure-imap": {
"listen": ["0.0.0.0:993"],
"routes": [
"handle": [
"handler": "tls"
"handler": "proxy",
"proxy_protocol": "v1",
"upstreams": [
{"dial": ["localhost:5432"]}
