POST to an ip/path endpoint or perform curl command?
I have an http endpoint on same vlan with caddy that triggers an action when accessing http://username:password@ip.ip.ip.ip:80/api?do=start&Key=12345
I want to be able to access and perform a POST to that endpoint over wan through caddy.
I have tried rewrite, redirect, and some other configs to no success.
Does caddy support proxying to a path endpoint like above? Or does caddy support performing curl commands when a particular address is requested? I do not need anything to be sent back to the user and only need to post the command to the ip path endpoint.
apt
debian12
https://subdomain.fqdn.com {
    reverse_proxy * http://usernam:password@ip.ip.ip.ip:80/api?do=start&Key=12345
You can try this (I’m typing it on a phone, so apologies about any typos):
    rewrite * /api?do=start&Key=12345
    method /* POST
    request_header Authorization “Basic B64CREDS”
    reverse_proxy http://ip.ip.ip.ip:80
where B64CREDS is base64 encoded string:
username:password
Use this webpage only as an example of how to create B64CREDS!
You could also try this, maybe?
    reverse_proxy * http://ip.ip.ip.ip:80 {
        rewrite /api?do=start&Key=12345
        method POST
        header_up Authorization “Basic B64CREDS”
Hi, I very appreciate your posting and thanks for writing clearly on your phone.
After testing I found that the destination for the reverse proxy is not basic auth but it is digest auth. For testing I simply removed the lines with request_header Authorization .
In testing, caddy successfully proxied a browser client to the destination and the browser popped up an input box for username and password which appears to get passed to destination but then I get error 400 Bad Request.
I added a log line to the config ie
output file /var/log/caddy/testing.log
level DEBUG
and caddy logs the error with access info however I do not see anything regarding the rewrite of the query parameters I was to be injected/appended.
{“level”:“error”,“ts”:1735880796.871118,“logger”:“http.log.access.log0”,“msg”:“handled request”,“request”:{“remote_ip”:“ip.ip.ip.ip”,“remote_port”:“46223”,“proto”:“HTTP/2.0”,“method”:“GET”,“host”:“subdomain.fqdn.com”,“uri”:“/”,“headers”:{“Upgrade-Insecure-Requests”:[“1”],“Sec-Fetch-Mode”:[“navigate”],“Sec-Fetch-Site”:[“cross-site”],“User-Agent”:[“Mozilla/5.0 (Android 12; Mobile; rv:133.0) Gecko/133.0 Firefox/133.0”],“Accept”:[“text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8”],“Accept-Language”:[“en-US”],“Accept-Encoding”:[“gzip, deflate, br, zstd”],“Sec-Gpc”:[“1”],“Dnt”:[“1”],“Priority”:[“u=0, i”],“Te”:[“trailers”],“Authorization”:,“Sec-Fetch-Dest”:[“document”]},“tls”:{“resumed”:false,“version”:772,“cipher_suite”:4865,“proto”:“h2”,“server_name”:“subdomain.fqdn.com”}},“user_id”:“”,“duration”:0.004262169,“size”:226,“status”:400,“resp_headers”:{“Content-Length”:[“226”],“Date”:[“Fri, 03 Jan 2025 05:06:36 GMT”],“Content-Type”:[“text/html; charset=iso-8859-1”],“Server”:[“Caddy”,“Apache/2.4.41 (Unix) OpenSSL/1.0.2t”],“Alt-Svc”:[“h3=":443"; ma=2592000”]}}
I don’t believe the rewrite is working correctly and I need to do more testing.
I have read Global options (Caddyfile) — Caddy Documentation and don’t see what is missing for more verbose logging.
How can I log or get more verbose information on what operations caddy is performing regarding the rewrite because I do not see them in the log output file.
You can enable debug mode by adding debug in the global options section. You can also add trace inside servers in the global options.
