Hi,
I am using Caddy version 0.9.1.
I am using the proxy method to successfully proxy a couple of domains at the moment.
I’d like to take this further if possible and proxy to a sub folder on a target server, is this possible to do?
This is an example that is working well for me without a sub folder:
support.domain.com:443 {
proxy / support.otherdomain.com {
proxy_header Host {host}
proxy_header X-Real-IP {remote}
proxy_header X-Custom-SSL “true”
Thank you for any guidance.
matt
(Matt Holt)
2
Try proxy / support.otherdomain.com/subfolder?
I tried that also. Sorry, I should have included that in my example.
I tried it and it just opens the root folder as if the /subfolder wasn’t there.
matt
(Matt Holt)
4
I don’t understand exactly what you mean by this then:
Don’t you just append the subfolder to the request then?
Did you try add the sub folder with a rewrite?
system
(system)
Closed
6
