Possible to keep Caddy up even if there is a single server runtime error?
v1
One somewhat irritating thing about caddy (and it may not be caddy but systemd) is that when a single entry has an error it brings the whole caddy server down.
For example I have a entry like so
https://xxxxx.org {
        tls xxxxxr@gmail.com
        fastcgi / /var/run/php/php7.2-fpm.sock php
        root /mnt/data/webs/smnordic
    rewrite / {
        if {path} not_match ^\/wp-admin
        to {path} {path}/ /index.php?_url={uri}
and because the dns record has not propogated letsencryt throws an error that then brings the whole Caddy server down even though all the other entries(servers) are fine. This is a bummer cause when I am trying to work out the settings for a new server I end up bringing the Caddy down. This can’t really be intended???
I run caddy via a systemd service so I tried putting a - in the start command per docker - Reset / Ingnore non-zero exit code with fleet / systemd - Server Fault but that did not work.
I understand if there is a syntax error then it wont run no matter what but can’t a runtime error of a single server entry not bring all of caddy down? If so how?
BTW is this issue addressed in V2? If I send v2 a bad entry or have a runtime issue on a single server’s settings will that not affect the rest of my operational caddy server?
here is my current unit file
RequiresMountsFor=/mnt/data
After=network-online.target mnt-data.mount
Restart=on-abnormal
User=root
Group=root
Environment=CADDYPATH=/opt/caddy/certs
; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
ExecStart=-/opt/caddy/caddy -log stdout -agree=true -conf=/opt/caddy/caddy.conf -root=/var/tmp
ExecReload=/bin/kill -USR1 $MAINPID
; Use graceful shutdown with a reasonable timeout
KillMode=mixed
KillSignal=SIGQUIT
; Unmodified caddy is not expected to use more than that.
;PrivateTmp=true
; Use a minimal /dev (May bring additional security if switched to 'true', but it may not work on Raspberry Pi's or other devices, so it has been disabled in this dist.)
;PrivateDevices=false
;ProtectHome=true
;ProtectSystem=full
; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
;   This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
;ReadWriteDirectories=/etc/ssl/caddy
; They further restrict privileges that can be gained by caddy. Uncomment if you like.
;CapabilityBoundingSet=CAP_NET_BIND_SERVICE
;AmbientCapabilities=CAP_NET_BIND_SERVICE
;NoNewPrivileges=true
Actually, Caddy doesn’t “bring the whole server down” just because one domain can’t resolve. That’s a common misconception which is explained here, and which is not unique to Caddy: How to have bad domain in config skipped - #2 by matt
In Caddy 2, certificate management is asynchronous by default.
