The basic idea here is: I want to setup a typical reverse proxy but also want to be able to serve TLS-termating requests that arrive destined anywhere on :443. Use case would be Caddy sitting in between a cloud load balancer and an application backend: I want the load balancer to be able to hit the instance’s routable IP address, but the load balancer may not know about what hostname the backend instance is serving: it just wants to see a response (either HTTP or HTTPS) after making the request.
I strongly suspect this is SNI-related, since I can invoke curl with --resolve and get a response back for any hostname - but the hostname has to be there first.
I can also get an internal wildcard name for the IP address - as long as its’ listed in a host matcher. But the trick here is that the instance doesn’t know how the upstream load balancer is going to hit it.
The sort of things that I expect might make what I want work, but haven’t so far:
- Using
default_sni,fallback_sni, orstrict_sni_host insecure_off - Ensuring that a
host *matcher is set
What I get back from curl:
$ curl -k https://127.0.0.1
curl: (35) OpenSSL/3.0.14: error:0A000438:SSL routines::tlsv1 alert internal error
What I want to see - note I can trick this into working by using --resolve, I assume because of SNI?
$ curl --resolve foo:443:127.0.0.1 -k https://foo
Hi
v.2.8.4
I’m isolating this behavior into a local xcaddy build (because my environment also ships the rate-limiter module).
NixOS 24.05, though the smallest-reproducible-config is pretty simple and my OS/systemd/docker versions don’t directly apply here.
N/A
A few settings changed including a few SNI-related settings I tried that didn’t do much:
default_sni example.com
fallback_sni example.com
servers {
*:443 {
tls internal
respond "Hi"
