greenpau
(Paul G.)
May 23, 2022, 12:38pm
1
I want to load key-value pairs from AWS Secrets Manager and AWS Parameter Store. It should work the same way as env.X
(environment variable replacers).
client_id {aws.secrets.MY_APP_CLIENT_ID}
scope {aws.parameters.MY_APP_OAUTH_SCOPES}
I imagine this would require a developing a plugin. What type of the plugin it would be? Is there an example of someone doing similar stuff?
I think it would have to be an HTTP handler module for now, because we don’t have any plugin hooks for apps to add to the replacer.
But basically you just grab the replacer out of the context then set the stuff you want in it. Try to use the Map()
for performance.
You could yoink the values out of an App though, i.e. preload the data into an app struct, then use ctx.App()
to get it and fill the replacer.
greenpau
(Paul G.)
May 23, 2022, 4:25pm
3
@francislavoie , thank you! It would be nice to have a plugin type for this.
matt
(Matt Holt)
May 24, 2022, 3:28am
4
And “yoink” is the technical term
system
(system)
Closed
June 22, 2022, 12:39pm
5
