Plex websockets error
Hi there,
Moving my setup from nginx to Caddy and I’ve got most things working for Plex except for websockets. I am seeing regular websocket errors in the console/logfile which is preventing notifications and other activities that Plex uses websockets for.
Caddyfile:
plex.domain.com {
gzip
proxy / 192.168.1.3:32400 {
Error in console:
17/Sep/2018:17:13:07 +0000 [ERROR 502 /:/websockets/notifications] EOF
I’ve tried adding a websocket directive in my Caddyfile as well but doesn’t seem to do anything.
Any thoughts?
Thanks!
Where did you put websocket? Keep in mind there is a difference between the websocket directive and the websocket subdirective. You want the latter - check the proxy docs:
https://caddyserver.com/docs/proxy#presets
Was able to solve it, not sure if it’s the most optimized way to do it, but adding below in case anyone stumbles onto this.
plex.domain.com {
        gzip
        timeouts 1h
                websocket
                keepalive 12
                timeout 1h
