Please Help. I think this is an easy fix
Hi everyone,
I am total noob here with proxying.
I am trying to get a domain I have to point to the ombi app.
So example.com to localhost:5000
I have dns in cloudfare setup correctly.
I have also confirmed ports 80 & 443 are open.
When I startup caddy i run an admin cmd session and then type C:\Caddy\caddy.exe -host example. com
It says its serving http & https on ports 443 & 80
However when I try to go to example.com I just get 404 Not Found
Here is my caddy file:
example.com, www.example.com {
gzip
proxy / 127.0.0.1:5000 {
Please Help! Thanks
On the startup command please ignore the space between . com. This site wouldnt let me post without adding that space because too many links for new user
In your caddy file, you will need to explicitly state where the root directory of your website is, and if it uses html or php
For example, try adding this to your caddy file
index index.html
root C:\Path\to\Website\files
Also, trying using caddy.exe -conf C:\path\to\caddyfile instead of host
So Ombi is an application tied into plex that runs its own webserver. If i go to mydomain.com:5000 I can reach it from outside my network. However my goal is to get it so I just have to go to mydomain.com and reach it.
You just need to ensure that Caddy is reading from the Caddyfile you want it to.
Ditch the -host flag and use -conf instead; Caddy should figure out the hostname from your Caddyfile.
C:\Caddy\caddy.exe -conf C:\path\to\Caddyfile
P.S.: mydomain.com is owned by a registrar and is currently hosted by an Apache server. example.com is the right domain to use for demonstration or example purposes.
That worked! Thanks so much
