Hello, I’m hoping I can find someone a lot smarter than myself to help me convert this over. The Nginx file is as followed
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
listen 80;
listen [::]:80;
server_name example.com;
# Useful for Let's Encrypt
location /.well-known/acme-challenge/ { allow all; }
location / { return 301 https://$host$request_uri; }
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_protocols TLSv1.2;
ssl_ciphers HIGH:!MEDIUM:!LOW:!aNULL:!NULL:!SHA;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
ssl_dhparam /etc/ssl/certs/dhparam.pem;
keepalive_timeout 70;
sendfile on;
client_max_body_size 0;
root /home/mastodon/live/public;
gzip on;
gzip_disable "msie6";
gzip_vary on;
gzip_proxied any;
gzip_comp_level 6;
gzip_buffers 16 8k;
gzip_http_version 1.1;
gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
add_header Strict-Transport-Security "max-age=31536000";
add_header Content-Security-Policy "style-src 'self' 'unsafe-inline'; script-src 'self'; object-src 'self'; img-src data: https:; media-src data: https:; connect-src 'self' wss://example.com; upgrade-insecure-requests";
location / {
try_files $uri @proxy;
location ~ ^/(packs|system/media_attachments/files|system/accounts/avatars) {
add_header Cache-Control "public, max-age=31536000, immutable";
location @proxy {
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header Proxy "";
proxy_pass_header Server;
proxy_pass http://127.0.0.1:3000;
proxy_buffering off;
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
tcp_nodelay on;
location /api/v1/streaming {
proxy_pass http://localhost:4000;
proxy_redirect off;
tcp_nodelay on;
error_page 500 501 502 503 504 /500.html;
I can send you the copy I created, but I don’t think it’s working as it should. Push notifications are suppose to work off the api via WebSocket, but push notifications are not working as they should. I’ve noticed that /if/ I get a push notification, it’s only when my phone is on the same network as the server. I do not receive them while on cellular, or another network. Thanks in advance!
