Please confirm that ACME (as client) + GSS-TSIG is not supported? (rfc-2136 isn't enough)
Hello,
In a totally closed and internal LAN project, I’m trying to use Canasta (one method to install Mediawiki) which uses Caddy. We already have our own ACME server (“step-ca”) and our DNS is served by Microsoft Active Directory. All this project does not communicate with the outer world.
I was trying to configure the Caddyfile to make Caddy get a certificate from our step-ca server and to use GitHub - caddy-dns/rfc2136 plugin to answer to the DNS challenge.
This rfc2136 plugin does not suit the requirements of MS-AD DNS, which requires a GSS-TSIG authentication (in another context, we are already successfully using a script that does that, by getting a Kerberos token beforehand the ns-update).
It this point, I don’t see how I could answer an internal DNS challenge as long as our DNS is Active Directory.
Before looking for another strategy, I would have your opinion on this situation, please.
Thank you.
One possible solution - you could run a self-hosted ACME-DNS server in your network. Caddy has a module for such server.
Then, in AD DNS, just delegate _acme-challenge.YOUR-DOMAIN via CNAME to such internal ACME-DNS server.
I get LE wildcard certs for my Caddy by using ACME-DNS SaaS, but you should be able to adjust it for the self-hosted ACME-DNS.
