PKI with default CAs not working
1. Caddy version (caddy version): 2.3.0
docker-compose
Docker (2.3.0-alpine)
docker-compose up
version: "3.7"
    image: caddy:2.3.0-alpine
      - "2019:2019"
      - caddy_data:/data
      - caddy_config:/config
  other_container:
    build:
      dockerfile: ./Dockerfile
      context: ./
  caddy_data:
  caddy_config:
Caddyfile used to initialise server
	admin 0.0.0.0:2019
mycaddy.local {
	reverse_proxy other_container:8080 {
		header_up X-mTLScertHash {http.request.tls.client.fingerprint}
		issuer internal {
			ca "local"
After init I try to /load the following JSON config (the same happens if just POSTing the new segment to /config/apps/pki etc.):
    "admin": {
        "listen": "0.0.0.0:2019"
    "apps": {
        "http": {
            "servers": {
                "srv0": {
                    "listen": [
                        ":443"
                    "routes": [
                            "handle": [
                                    "handler": "subroute",
                                    "routes": [
                                            "handle": [
                                                    "handler": "reverse_proxy",
                                                    "headers": {
                                                        "request": {
                                                            "set": {
        "X-Mtlscerthash": [
        "{http.request.tls.client.fingerprint}"
                                                    "upstreams": [
                                                            "dial": "other_container:8080"
                            "match": [
                                    "host": [
                                        "mycaddy.local"
                            "terminal": true
        "tls": {
            "automation": {
                "policies": [
                        "issuers": [
                                "ca": "local",
                                "module": "internal"
                        "subjects": [
                            "mycaddy.local"
        "pki": {
            "certificate_authorities": {
                "local": {
                    "name": "Default Client CA",
                    "root": {},
                    "intermediate": {}
Im trying to get PKI working with default CA for both. The server starts fine with Caddyfile above. When updating the config by POSTing the above JSON config to /load it does not result in a working PKI configuration but the below error message.
{“error”:“loading config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: provisioning automation policy 0: loading TLS automation management module: position 0: loading module ‘internal’: provision tls.issuance.internal: loading pki app module: provision pki: provisioning CA ‘local’: open : no such file or directory”}
I have had a look in container and a key pair has been generated in /data/caddy/pki/authorities/local
Hmm. My guess is that these lines are messing it up. I think setting these to empty objects means that Caddy is looking for a file at "", i.e. empty string.
Ah yes. Sorry I thought that when it said ‘empty’ in documentation it meant empty object. Thanks for your help.
I’ll change that to “null”.
