I just downloaded phpMyAdmin-5.1.0-all-languages.zip and installed it on my VPS in /usr/share/phpMyAdmin/.
sudo systemctl restart caddy
[yves@sd-163808 phpMyAdmin]$ cat /usr/lib/systemd/system/caddy.service
# caddy.service
# for your installation.
[yves@sd-163808 phpMyAdmin]$ cat /etc/caddy/Caddyfile
team-tabulos.com
roll_keep_for 8760h
root * /opt/tabulos
php_fastcgi /phpmyadmin/* unix//run/php-fpm/www.sock {
root /usr/share/phpMyAdmin/
php_fastcgi unix//run/php-fpm/www.sock
I am trying to have phpmyadmin working on my machine. I though it would be a good idea to implement it as a specific route on my domain name: team-tabulos.com/phpmyadmin for instance. So I added the following directive in my caddy file:
Then I pointed to team-tabulos.com/phpmyadmin/index.php from my browser, and as a result the page remains all blank. What is surprising is that I get a lot of error in the javascript console.
Actually, from what I see, I have an error for each css ressource, like this one:
Did not parse stylesheet at 'https://team-tabulos.com/phpmyadmin/themes/pmahomme/css/printview.css?v=5.1.0' because non CSS MIME types are not allowed in strict mode.
And for each javascript file, I have an error message looking like that:
Refused to execute https://team-tabulos.com/phpmyadmin/js/vendor/jquery/jquery.min.js?v=5.1.0 as script because "X-Content-Type-Options: nosniff" was given and its Content-Type is not a script MIME type.
Moreover, if I look into the response header, I can see that the Content-Type is set to:
Content-Type: text/html; charset=utf-8
for each of those two files, and for any file I am trying to look at. There’s even four files (logo images) who all four see their Content-Type set to text/html. So I guess that every response set its Content-Type to text/html.
Even though I am not a web developper, I guess it’s not the correct value… So I guess there’s an issue with the correct Content-Type answered by Caddy. (Am I wrong or right?)
There’s a lot of lines in the caddy log file. If you ask for it specifically, I can make the effort to copy/paste it here. For instance for the file printview.css, if you ask for it.
I’ve tried to solve my issue by rewriting the Content-Type header at the fly with some directives. I’ve wrote that in my configuration file:
header /phpmyadmin/*.js {
Content-Type 'text/javascript'
But it did not worked. (I think I am far from mastering the CaddyFile) How would you do to make Caddy specify the correct Content-Type?
