Just started to play with Caddy and I intend to use it on a domain name with multiple sub-domains. They all use php-cgi and to get them working properly I have to redeclare the fastcgi directive in all sub-domain block.
Is there any way to achieve this with wild cards? Like this:
example.com {
root /var/www
fastcgi / /var/run/php/php7.0-fpm.sock {
ext .php
split .php
index index.php
*.example.com {
ext .php
split .php
index index.php
subdomain1.example.com {
root /var/www/allowip
gzip
subdomain2.example.com {
root /var/www/plp
gzip
matt
(Matt Holt)
January 3, 2018, 5:59pm
#2
The Caddyfile does not have inheritance, or wildcards in the sense that you want.
But you can simplify your fastcgi config to just one line:
fastcgi / /var/run/php/php7.0-fpm.sock php
And then you can easily put that in each site that needs it, because it is only a single line.
Some people like to use import
to share common configuration, but for just one line it’s not benefitting you much.
Thank you for that php one-liner. I will aslo have a look to the import
function as I have more common options to configure.
system
(system)
closed
April 3, 2018, 6:22pm
#4
