Php query string is not showing
Hi,
I am trying to move a php booking application (bookedscheduler) from Apache to Caddy.
But I can not make the query string work.
With Apache:
When I go to https://apache.domain.ca/Web/schedule.php and click on a room to book time.
I get https://apache.domain.ca/Web/reservation/?rid=329&sid=4&rd=2023-08-30&sd=2023-08-30%2010%3A30%3A00&ed=2023-08-30%2011%3A00%3A00 and all is good.
With Caddy:
When I go to https://caddy.domain.ca/Web/schedule.php and click to pick a room.
I get https://caddy.domain.ca/Web/reservation/
Notice the query string is missing, I am not sure if this is a php.ini, caddyfile or code issue.
Any pointers in the right direction will be welcome.
v2.7.4
Debian package from the cloudsmith.io repo
OS: Ubuntu 22.04.3 LTS x86_64
PHP: 8.1.2-1ubuntu2.14
systemctl restart caddy
 #debug
  email tech@caddy.domain.ca
  log default {
    output file /var/log/caddy/caddy.log
      format console {
        time_local
(common) {
  header /* {
    -Server
caddy.domain.ca {
  import common
  root * /var/www/html/booked/
  encode zstd gzip
  php_fastcgi unix//run/php/php8.1-fpm.sock
  handle_path /stats* {
    root * /var/www/html/goaccess
      output file /var/log/caddy/booking.log
Where are you seeing this? Enable the debug global option and show your logs. Make an example request with curl -v.
