PHP Nextcloud - PROPFIND method not allowed error (v2)
I’m trying to migrate from V1 to V2 for my NextCloud website too.
I use simple rule like this :
root * /var/www/html
log
redir /.well-known/carddav /remote.php/carddav 301
redir /.well-known/caldav /remote.php/caldav 301
header Strict-Transport-Security max-age=31536000;
php_fastcgi unix//var/run/php/php7.4-fpm.sock
The website work but the Webdav part not …
ERROR http.log.access handled request {“request”: {“method”: “PROPFIND”, “uri”: “/remote.php/dav/files/XXX/data” … “size”:0, “status”:405,
Any idea why ?
Hi @max3163,
Your issue wasn’t related to the previous thread regarding rewrite rules, so I’ve moved it to its own topic.
This 405 is an interesting one. As far as I can tell, Caddy v2 itself only ever generates this status for bad API requests, never requests to its HTTP server, which kinda implies that Nextcloud threw this error via PHP.
The exact request is
fetch(“https://xxx/remote.php/dav/files/xxx/”, {
“headers”: {
“accept”: “/”,
“accept-language”: “fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7”,
“content-type”: “application/xml; charset=UTF-8”,
“depth”: “1”,
“requesttoken”: “132465798”,
“sec-fetch-dest”: “empty”,
“sec-fetch-mode”: “cors”,
“sec-fetch-site”: “same-origin”,
“x-requested-with”: “XMLHttpRequest”
“referrerPolicy”: “no-referrer”,
“body”: “<?xml version=\"1.0\"?>\n<d:propfind xmlns:d="DAV:" xmlns:oc="http://owncloud.org/ns\” xmlns:nc="Nextcloud - Open source content collaboration platform" xmlns:ocs="http://open-collaboration-services.org/ns\“>\n <d:prop>\n <d:getlastmodified />\n <d:getetag />\n <d:getcontenttype />\n <d:resourcetype />\n <oc:fileid />\n <oc:permissions />\n <oc:size />\n <d:getcontentlength />\n <nc:has-preview />\n <nc:mount-type />\n <nc:is-encrypted />\n <ocs:share-permissions />\n <oc:tags />\n <oc:favorite />\n <oc:comments-unread />\n <oc:owner-id />\n <oc:owner-display-name />\n <oc:share-types />\n </d:prop>\n</d:propfind>”,
“mode”: “cors”,
“credentials”: “include”
And the full error
ERROR http.log.access handled request {“request”: {“method”: “PROPFIND”, “uri”: “/remote.php/dav/files/xxx/”, “proto”: “HTTP/2.0”, “remote_addr”: “XX.XX.XX.XX:XXXX”, “host”: “xxxx”, “headers”: {“Content-Length”: [“621”], “Requesttoken”: [“132465”], “X-Requested-With”: [“XMLHttpRequest”], “Sec-Fetch-Mode”: [“cors”], “Content-Type”: [“application/xml; charset=UTF-8”], “User-Agent”: [“Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.92 Safari/537.36”], “Origin”: [“https://xxxx”], “Sec-Fetch-Dest”: [“empty”], “Accept”: [“/”], “Sec-Fetch-Site”: [“same-origin”], “Accept-Encoding”: [“gzip, deflate, br”], “Cookie”: [“__Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true; nc_username=xxx; login_cookie=123; login_salt=594; DMZSID=123; oc_sessionPassphrase=132465; octpkzxlr0kf=132; nc_token=123; nc_session_id=132”], “Depth”: [“1”], “Accept-Language”: [“fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7”]}, “tls”: {“resumed”: false, “version”: 772, “ciphersuite”: 4865, “proto”: “h2”, “proto_mutual”: true, “server_name”: “xxx”}}, “common_log”: “192.168.1.11 - - [17/Apr/2020:10:37:40 +0200] "PROPFIND /remote.php/dav/files/xxx/ HTTP/2.0" 405 0”, “latency”: 0.034660517, “size”: 0, “status”: 405, “resp_headers”: {“X-Permitted-Cross-Domain-Policies”: [“none”], “Pragma”: [“no-cache”], “Referrer-Policy”: [“no-referrer”], “Status”: [“405 Method Not Allowed”], “Content-Type”: [“text/html; charset=UTF-8”], “X-Robots-Tag”: [“none”], “X-Frame-Options”: [“SAMEORIGIN”], “Expires”: [“Thu, 19 Nov 1981 08:52:00 GMT”], “X-Content-Type-Options”: [“nosniff”], “X-Download-Options”: [“noopen”], “Content-Security-Policy”: [“default-src ‘self’; script-src ‘self’ ‘nonce-123’; style-src ‘self’ ‘unsafe-inline’; frame-src *; img-src * data: blob:; font-src ‘self’ data:; media-src *; connect-src *; object-src ‘none’; base-uri ‘self’;”], “Strict-Transport-Security”: [“max-age=31536000;”], “Cache-Control”: [“no-store, no-cache, must-revalidate”], “X-Xss-Protection”: [“1; mode=block”], “Server”: [“Caddy”]}}
With the V1 of caddy, it work with response status
  1. server: Caddy
  2. status: 207
  3. status: 207 Multi-Status
No error on nextcloud log.
@max3163 f you add:
to the beginning of your Caddyfile, it will enable debug logging which will provide a little more introspection into what the proxy is sending and receiving. Don’t know if that will be helpful but it might help identify a misconfiguration in Nextcloud.
@max3163 Hey if you remove the log directive, does it happen to work? :thinking:
@max3163 It seems we’ve found a solution in a neighboring thread: Help to migrate Caddyfile V1 to V2 for Nextcloud - #18 by francislavoie
