Php content showing without formatting or images
Debian Buster, php7.3-fpm.
sudo systemctl start caddy
sudo caddy reload # After edits of the Caddyfile
# caddy.service
# for your installation.
mala.fr, www.mala.fr {
        tls ma@email.com
        root * /var/www/mala.fr/wordpress
        php_fastcgi unix//run/php/php7.3-fpm.sock
        # Prevent malicious PHP uploads from running
        @uploads {
                path_regexp path /uploads\/(.*)\.php
        rewrite @uploads /
grav.mala.fr, www.grav.mala.fr {
        root * /var/www/mala.fr/grav/base
mattermost.mala.fr, www.mattermost.mala.fr {
        reverse_proxy 127.0.0.1:8065
I just recently discovered Caddy and I’m quite impressed with the simplicity of Caddyfiles. I was using Nginx before and could never understand 10% of my own configuration files. I decided to try Caddy and got it working for maybe 20 minutes, then suddenly my PHP websites (the main domain and the grav subdomain) started to display as if there was no formatting on the web pages: no images, no correct alignment, no header, etc.
What I do not understand is it was working a few minutes before and I don’t think I changed anything sensible. I was editing my Caddyfile when that happened, but on some other aspects like beautifying my identation or improving comments, and I tried reverted the changes just in case. I really can’t see what has changed between now and when it was working.
Could it be related to a certificate issue blocking the access to some resources called by the Wordpress and Grav sites? Or some cache issue?
The mattermost instance works fine for now.
I see no particular error.
I tried commenting out the tls part, triple checked the php-fpm version for php_fastcgi, tried disabling subdomains one by one, to no avail: I could not get back to a state where things worked.
Of note, I then tried from another device, and there again the main page was displayed correctly, until I refreshed it. This makes me wonder if it may involve the cache from a previous visit when Nginx was service those website, as if the website could show correctly by chance thanks to resources already in my cache, but then failing to actually load images and formatting when I refreshed. The weird thing is I hard refreshed maybe 20 times on the first device before everything broke.
Alright, I understood my error. I was missing file_server in both PHP websites. Not sure if it’s me being too tired to realize I deleted it just before things broke, of if the cache actually kept the website working for some time without it, until it broke eventually and I couldn’t directly relate the effect to the cause.
