I’m trying to both maintain a single Caddyfile and also any additions made from the API call additions.
It works straight away with no configuration if i’m using caddy-api
as it has the persist
enabled.
However, if at any given point I want to do a caddy reload
because I changed the Caddyfile
my additions from the API requests will be gone as I understand because it just loads the Caddyfile.
My question is, how do I update the Caddyfile without the changes from API calls being lost?
No errors.
Through it’s automatic systemd configuration.
Had to disable caddy
and enable caddy-api
though.
systemctl start caddy-api
