Pattern Matching Index (simple)
1. Caddy version (caddy version): 2.4.5
docker-compose up caddy (with official caddy:alpine)
N/A
N/A
N/A
fancydomain.com {
        handle / {
                rewrite * /pages/lp
                reverse_proxy nuxt:8001
        handle /* {
For backend reasons, I need to reverse proxy index ( https://fancydomain.com ) to /pages/lp and everything else do just reverse proxy with same path.
E.g.
/ → nuxt:8001/pages/lp (The Special case I am trying to introduce)
/xyz → nuxt:8001/xyz
/hello/world → nuxt:8001/hello/world
No Error messages, but it is letting
https://fancydomain.com go to nuxt:8001/ instead of https://fancydomain go to nuxt:8001/pages/lp
If I remove the handle /* part (see below) then it works with the special case, but everything else fails.
It seems like the handle /* overrides the handle /.
fancydomain.com {
        handle / {
                rewrite * /pages/lp
N/A
The handle blocks here are redundant, you can just do this:
fancydomain.com {
	rewrite / /pages/lp
The * in rewrite is the matcher, so you can just change it to / to only match requests to the root.
@francislavoie Thank you! I used so much time on this and I nearly pulled my non-existing hair out! :smiley:
Have an awesome week!
You too! Glad I could help
:grin:
