v2.2.0-rc.1
OS:
Distributor ID: Ubuntu
Description: Ubuntu 18.04.5 LTS
Release: 18.04
Codename: bionic
Running through Docker & Docker-Compose
(If the container is down)
docker-compose up -d
(If I just need to reload the config)
docker exec -w /etc/caddy caddy caddy reload
version: "3.7"
build: ./dns-dockerfile
hostname: caddy
- MY_DOMAIN
- CLOUDFLARE_API_TOKEN
- ./data:/data
- ./config:/config
default:
external:
(cloudflare) {
# tls {env.CLOUDFLARE_EMAIL}
(LAN_only) {
@fuck_off_world {
not remote_ip 24.227.248.138/24
respond @fuck_off_world 403
#@print_matcher {
# path_regexp ^(?:[0-9]{1,3}\.){3}[0-9]{1,3}$
{$MY_DOMAIN} {
import cloudflare
output file ~/caddylog {
roll_size 20mb
roll_keep 5
reverse_proxy 192.168.1.3:80
a.{$MY_DOMAIN} {
import cloudflare
reverse_proxy whoami:80
b.{$MY_DOMAIN} {
import cloudflare
reverse_proxy nginx:80
vault.{$MY_DOMAIN} {
import cloudflare
# Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "DENY"
# Prevent search engines from indexing (optional)
X-Robots-Tag "none"
# Server name removing
-Server
# Notifications redirected to the websockets server
reverse_proxy /notifications/hub bitwarden:3012
# Proxy the Root directory to Rocket
reverse_proxy bitwarden:80
wiki.{$MY_DOMAIN} {
import cloudflare
output file /data/logs/bookstack_access.log {
roll_size 20mb
roll_keep 5
#reverse_proxy bookstack:80
reverse_proxy bookstack:443 {
tls
tls_insecure_skip_verify
print.{$MY_DOMAIN} {
import cloudflare
route {path} {
#uri strip_prefix {path}
reverse_proxy {path} {
to {query}/:80
#insecure_skip_verify
# header_up +X-Frame-Options SAMESITE
header_down -X-Frame-Options
header_down -Host
#header_down +X-Frame-Options ALLOW-FROM {MY_DOMAIN}
#uri strip_prefix {query}
Some background:
I’m trying to set up a “Printer Page” for the administrative staff at the company I work at. The concept is that they can add the printer and it’s IP address to a database, and then view all of the different printer pages from a table of links.
Image for reference:
Anyways, I wanted to have the printer pages all on a single subdomain and have caddy redirect the request to the proper page. Now, my current code does work, but it seems to be acting as a redirect instead of a reverse proxy, so the printer settings page will not show up within an iframe.
Here’s the error I get from caddy whenever I attempt to load any of the printers within the iframe:
"level":"debug",
"ts":1599843213.0695734,
"logger":"http.handlers.reverse_proxy",
"msg":"upstream roundtrip",
"upstream":"{http.request.uri.query}/:80",
"request":{
"method":"GET",
"uri":"/192.168.1.16/",
"proto":"HTTP/1.1",
"remote_addr":"162.158.187.70:20172",
"host":":80",
"headers":{
"X-Forwarded-For":[
"24.227.248.138, 162.158.187.70"
"Cache-Control":[
"no-cache"
"Sec-Fetch-User":[
"?1"
"Cf-Ray":[
"5d12e5855b3107d6-ATL"
"Accept":[
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
"Cdn-Loop":[
"cloudflare"
"X-Forwarded-Proto":[
"https"
"Upgrade-Insecure-Requests":[
"1"
"Pragma":[
"no-cache"
"Accept-Language":[
"en-US,en;q=0.9"
"Sec-Fetch-Site":[
"same-site"
"Cf-Ipcountry":[
"US"
"Sec-Fetch-Mode":[
"navigate"
"User-Agent":[
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.83 Safari/537.36"
"Cf-Connecting-Ip":[
"24.227.248.138"
"Referer":[
"https://vprsrv.org/printers.php"
"Cf-Request-Id":[
"051fadc75b000007d6e73a3200000001"
"Cookie":[
"__cfduid=d8703413d8c110a3d1e7a08b7b6194e0a1599759255"
"Cf-Visitor":[
"{\"scheme\":\"https\"}"
"Sec-Fetch-Dest":[
"iframe"
"Accept-Encoding":[
"gzip"
"tls":{
"resumed":false,
"version":772,
"ciphersuite":4867,
"proto":"",
"proto_mutual":true,
"server_name":"print.vprsrv.org"
"headers":{
"Date":[
"Fri, 11 Sep 2020 16:53:33 GMT"
"Content-Length":[
"0"
"Location":[
"https:///192.168.1.16/"
"Server":[
"Caddy"
"duration":0.00080883,
"status":308
"level":"info",
"ts":1599843213.069884,
"logger":"http.log.access",
"msg":"handled request",
"request":{
"method":"GET",
"proto":"HTTP/1.1",
"host":"print.vprsrv.org",
"headers":{
"Sec-Fetch-User":[
"?1"
"Referer":[
"Cf-Request-Id":[
"Cdn-Loop":[
"cloudflare"
"Cf-Ipcountry":[
"US"
"X-Forwarded-For":[
"24.227.248.138"
"Cache-Control":[
"no-cache"
"Sec-Fetch-Site":[
"same-site"
"https"
"1"
"Sec-Fetch-Mode":[
"navigate"
"Cookie":[
"24.227.248.138"
"Cf-Visitor":[
"Pragma":[
"no-cache"
"User-Agent":[
"Sec-Fetch-Dest":[
"iframe"
"Accept":[
"Accept-Language":[
"en-US,en;q=0.9"
"Connection":[
"Keep-Alive"
"Accept-Encoding":[
"gzip"
"Cf-Ray":[
"tls":{
"resumed":false,
"version":772,
"ciphersuite":4867,
"proto":"",
"common_log":"162.158.187.70 - - [11/Sep/2020:16:53:33 +0000] \"GET /192.168.1.16/ HTTP/1.1\" 308 0",
"duration":0.001026267,
"size":0,
"status":308,
"resp_headers":{
"Server":[
"Caddy",
"Caddy"
"Date":[
"Content-Length":[
"0"
"Location":[
As I mentioned before, my current code works (if you go to the url in a new tab at least), but it redirects to the printer’s IP address. I’m pretty sure this is due to this: header_up Host {http.reverse_proxy.upstream.hostport}
, but removing that doesn’t allow me to access the printers at all.
I also have gotten this to work, but only when I reverse proxy all paths to a specific subdomain (i.e.
reverse_proxy 192.168.1.100:80
). As much as I would like for that to be the solution, it requires someone to change the Caddyfile anytime a new printer is added (or whose IP changes), which isn’t realistic for the administrative staff.
Other things I’ve tried…
Using the transport directive:
reverse_proxy {path}:443 {
tls
I’ve also tried using regex:
@static {
path_regexp static (.[0-9]{1})+
reverse_proxy @static {
to {http.regexp.static.1}/:80
And finally what I started with:
reverse_proxy {path}:80
Help is much appreciated!
