Raspberry Pi OS 05-27-2020 (previously called Raspbian) based on Debian 10 (Buster). I am running it on a Raspberry Pi. I followed the installation procedure on Caddy’s wesbsite.
I am not running on docker. I assume it is systemd given I used caddy.service inside /etc/systemd/system and use systemctl command.
sudo systemctl start caddy
# caddy.service
# for your installation.
After=network.target
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile
root /main/* /var/www/
under /var/www I have a test HTML file. However, when I try to hit my IP from another computer on the same network with this: <Raspberry_Pi_IP_Address>/main it does not work. However, when I had my config file as follows below:
root * /var/www/
and in my browser I go to just the IP address http://<Raspberry_Pi_IP_Address>, it works correctly and the HTML file loads.
no particular error message. It just does not load
I have tried different configurations for the Caddyfile. I mentioned using just root * above, but I also tried the following:
root /main /var/www/
and
<IP_ADDRESS>/main:80 {
root * /var/www/
and other combinations
Please help me! thanks to all in advance!
