Hi,
It is possible to pass a param to an included file? {{.Include "path/to/file.html"}}
or anyway to achieve something like this:
{{.Include "path/to/file.html" .param.name="John"}}
and in file.html
Hello {{.param.name}}
Thanks.
Hi,
and in file.html
Thanks.
Nope, but I suppose someone could look into whether this is trivial to implement. If so, we could accept it as a change.
Did someone look at this feature ?
Thanks.
If you post this as an issue in the github repository, someone may have time to take a look at it.
https://github.com/mholt/caddy/issues
I actually just needed something like this this weekend. I’m implementing it like so:
{{.Include "path/to/file.html" "arg1" "arg2"}}
and then inside file.html:
{{index .Args 0}} <!-- arg1 -->
{{index .Args 1}} <!-- arg2 -->
Would that be acceptable? In my case, I need to pass a <title> value into the included header file. So this works for me. But I’m still double-checking if this is how I want it to look in Caddy, or if it should be sugared up a bit with a syntax like this:
{{.Param 0}}
Meaning, “the value of parameter 0” – or maybe “argument” is technically more correct and I don’t need to add any sugar…
Implemented in 22a266a. @geodeveloper
I went with the {{index .Args N}} syntax for now.
Thank you! I’m glad this was implemented! Keep up the good work!
