Partially applying auth to a reverse proxy / re-using an upstream
I want to require authentication for only a part of reverse proxy url space.
nodered.foo.com/public/* -> without auth
nodered.foo.com -> with auth
(auth) {
        forward_auth nforwardauth:9999 {
                uri /
nodered.foo.com {
        import auth
        reverse_proxy http://nodered:1880
What I have tried is:
nodered.foo.com {
        handle /public/* {
        import auth
What I am unclear here is whether specifying the upstream twice is a bad idea.
And for some reason auth seems to required also for /public
curl -k -I https://nodered.foo.com/public/foo
HTTP/2 307
alt-svc: h3=":443"; ma=2592000
date: Thu, 02 May 2024 13:09:28 GMT
location: https://auth.foo.com/login?r=https://nodered.foo.com/public/foo
NA
NA
Docker on x86
NA
NA
NA
NA
Just apply a matcher to forward_auth:
@auth not path /public/*
forward_auth @auth nforwardauth:9999
Fair point. That’s even easier.
But just for the learning: What’s wrong with my approach?
It would cause two reverse_proxy handlers to be loaded and in memory, so they would not share state (like health check status etc). In practice it doesn’t really matter. But it’s certainly cleaner to not repeat yourself in config.
Makes sense.
And why would /public/foo still be affected by the import auth outside the handle match?
I would have have expected this to only fall through for non /public/* and give a 404 when testing /public/foo but instead got a 307.
I don’t follow. Please share your config as it is now.
I have it working now - but I was wondering why this here:
would give me a 307 (requiring auth) for /public/foo.
Because forward_auth is higher on the directive order than handle, so it always runs first:
Thanks for the help! That cleared things up!
