Working on my Caddy integration into my LEMP stack, and I have setup
/etc/caddy/Caddyfile
as
import ./conf.d/*
with contents of /etc/caddy/conf.d
directory as
ls -lah /etc/caddy/conf.d
total 12K
drwxr-xr-x 2 root root 87 Aug 6 01:54 .
drwxr-xr-x 3 root nginx 35 Aug 6 00:03 ..
-rw-r--r-- 1 root root 760 Aug 6 00:06 host.domain1.com.conf
-rw-r--r-- 1 root root 787 Aug 6 02:02 domain1.com.conf
contents of host.domain1.com.conf
which works and starts Caddy fine
curl -I host.domain1.com:81
HTTP/1.1 200 OK
Accept-Ranges: bytes
Cache-Control: max-age=86400
Content-Length: 3801
Content-Type: text/html; charset=utf-8
Etag: W/"579b144d-ed9"
Last-Modified: Fri, 29 Jul 2016 08:31:09 GMT
Server: Caddy
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
X-Xss-Protection: 1; mode=block
Date: Sat, 06 Aug 2016 01:41:41 GMT
host.domain1.com:81 {
gzip {
level 6
min_length 1400
browse
header / {
Cache-Control "max-age=86400"
X-Frame-Options "SAMEORIGIN"
#-Server
tls off
root /usr/local/nginx/html
fastcgi / 127.0.0.1:9000 {
ext .php
split .php
index index.php
log / /usr/local/nginx/logs/centos7.localdomain-access.log "{remote} {when} {method} {uri} {proto} {status} {size} {>User-Agent} {latency}" {
rotate {
size 100 # Rotate after 100 MB
age 14 # Keep log files for 14 days
keep 10 # Keep at most 10 log files
contents of domain1.com.conf
which when added Caddy fails to start
domain1.com:81 {
gzip {
level 6
min_length 1400
browse
header / {
#-Server
tls off
root /home/nginx/domains/domain1.com/public
ext .php
split .php
index index.php
log / /home/nginx/domains/domain1.com/log/caddy-domain1.com-access.log "{remote} {when} {method} {uri} {proto} {status} {size} {>User-Agent} {latency}" {
rotate {
with domain1.com.conf
vhost file Caddy gives me ??
2016/08/06 02:02:02 domain1.com.conf:1 - Parse error: Unknown directive 'domain1.com:81'
what am I missing ?
