Overseerr and caddy possible?
1. Caddy version (caddy version):v2.4.6 h1:HGkGICFGvyrodcqOOclHKfvJC0qTU7vny/7FhYp9hNw=
2. How I run Caddy: caddy start
a. System environment: Windows 10
domains {
        tls email@gmail.com
        basicauth /movies/* {
                user PasswordHash        }
        basicauth /series/* {
                user PasswordHash
        redir /movies /movies/ 308
        redir /series /series/ 308
        redir /overseerr /overseerr/ 308
        reverse_proxy /movies/* localhost:7878
        reverse_proxy /series/* localhost:8989
        route  /overseerr/* {
                uri strip_prefix /overseerr
                reverse_proxy http://192.168.2.1:5055
                output file access.log
I’m trying to get Overseerr working with reverse_proxy.
When I goto https://my.domain.tld/overseerr it redirects me to https://my.domain.tld/login instead of https://my.domain.tld/overseerr/login
If I remove the uri strip_prefix /overseerr I get the following: ERR_TOO_MANY_REDIRECTS
rewrite /login* /overseerr/login
https://docs.overseerr.dev/extending-overseerr/reverse-proxy#nginx
You’re probably running into this:
Best to use a subdomain for each service instead.
Just to follow up on this one, I also run Overseerr; but, unlike my Sonarr/Radarr/NZBGet/etc, it gets its own subdomain.
Base URLs cannot be configured in Overseerr. With this limitation, only subdomain configurations are supported.
They actually do provide a list of header and HTTP filter rewrites - in the form of an explicitly unsupported nginx config - that can be converted to Caddy config to hopefully achieve the same explicitly unsupported results (as in part 2.B. of the subfolder problem wiki post), but I’d recommend not bothering.
Thanks for the reply guys, I’ll go with the subdomain.
