Caddy v2.0.0
As a service for reverse proxies and hosting Organizr hopefully.
Ubuntu Server 20.04 LTS
I have caddy running as a service so this is what I used to start it
sudo systemctl daemon-reload
sudo systemctl enable caddy
sudo systemctl start caddy
This is what I use to reload it after caddy file changes
sudo systemctl reload caddy
I am running it on the main OS, no containers or anything.
dankflix.xyz
reverse_proxy 192.168.1.100:5000
:8082 {
root * /var/www/dankflix.me/index.php
php_fastcgi / localhost:9000
3. The problem Iâm having:
Iâm unable to get Organizr to work in general. When navigating to 192.168.1.100:8082, it is just a white screen.
Caddy is running and active.
Jun 10 00:42:30 linux-server caddy[769]: 2020/06/10 00:42:30 http: TLS handshake error from 208.93.152.17:55122: no certificate available for âMy IP adrâ
Jun 10 00:53:40 linux-server caddy[769]: 2020/06/10 00:53:40 http: TLS handshake error from 146.88.240.11:47278: no certificate available for '192.168.1.100'
Jun 10 00:55:59 linux-server caddy[769]: 2020/06/10 00:55:59 http: TLS handshake error from 46.4.78.216:43810: no certificate available for 'dankflix.me'
Jun 10 00:56:55 linux-server caddy[769]: 2020/06/10 00:56:55 http: TLS handshake error from 172.105.89.161:41728: no certificate available for '192.168.1.100'
Jun 10 01:05:21 linux-server caddy[769]: 2020/06/10 01:05:21 http: TLS handshake error from 41.216.186.89:246: tls: first record does not look like a TLS handshake
Jun 10 01:17:55 linux-server caddy[769]: 2020/06/10 01:17:55 http: TLS handshake error from 46.4.78.216:60266: no certificate available for 'dankflix.me'
Jun 10 01:43:50 linux-server caddy[769]: {"level":"info","ts":1591771430.5392969,"logger":"tls","msg":"cleaned up storage units"}
Jun 10 02:29:23 linux-server caddy[769]: 2020/06/10 02:29:23 http: TLS handshake error from 71.6.146.186:36656: no certificate available for '192.168.1.100'
Jun 10 02:29:37 linux-server caddy[769]: 2020/06/10 02:29:37 http: TLS handshake error from 34.76.78.209:42265: no certificate available for '192.168.1.100'
Jun 10 02:54:07 linux-server caddy[769]: 2020/06/10 02:54:07 http: TLS handshake error from 193.118.53.210:37062: no certificate available for âMy IP adrâ
I used the bash script (steps posted below) and did the requirements install and then git cloned Organizr into my var/www/domain folder. I am new to Caddy/Caddy files so the issue is probably in there. I could not find any resources for organizr on Caddyv2 anywhere, the official install only has instructions for Nginx.
1) sudo apt-get install git
2) sudo git clone https://github.com/elmerfdz/OrganizrInstaller /opt/OrganizrInstaller
3) cd /opt/OrganizrInstaller/ubuntu/oui
4) sudo bash ou_installer.sh
5) Requirements install
6) sudo git clone https://github.com/causefx/Organizr /var/www/dankflix.me
Organizr GitHub readme
Organizr Install guide
https://docs.organizr.app/books/installation/page/ubuntudebian
Organizr Installer I also tried
Tried this as well with no luck
Let me know if I missed anything! Thereâs also a Organizr install with Caddy on GitHub that I have seen linked on a few forms during my research that is blank.
