I have a config that uses a snippet to handle some blocked clients, but they don’t get blocked by Caddy. I think it has to do with using handle directives and order / processing of the config file, but I honestly can’t make heads or tails of it anymore. I tried adding the abort in the last handle {} directive too, but no matter what, the clients are not blocked/aborted. I can see in the logs that the remote_ip / client_ip matches the specified ip in the snippet, but the requests just get passed through.
Edit: actually I think they did start getting blocked when I added the abort @banned
directive also into the last handle {}
block. I simply made the false assumption they were not blocked because requests still got logged (but they no longer had a response status code etc I noticed later).
I am just wondering now, do I need to add the abort @banned
directive into every handle[_path] {}
block?
Ubuntu 23.10
systemd 253 (253.5-1ubuntu6.1)
(banned) {
@banned {
remote_ip 1.2.3.4
remote_ip 5.6.7.8
domain.tld {
root * /path/to/root
import banned
abort @banned
handle_path /sub/* {
redir {uri} 301
@phpfile path *.php *.php/*
handle @phpfile {
error 403
@exists file
@staticFiles path *.jpg *.jpeg *.js *.css *.png *.woff *.woff2 *.otf *.ttf *.gif *.svg *.webp
handle @exists {
header @staticFiles Cache-Control "public, max-age=604800, s-maxage=86400, stale-while-revalidate=3600, must-revalidate"
header ?access-control-allow-origin *
header ?access-control-allow-methods "GET"
@skipvarnish path /admin* /api/*
handle @skipvarnish {
reverse_proxy {
to http://localhost:8080
header_up x-real-ip {remote_host}
header_up x-request-id {http.request.uuid}
dial_timeout 2s
keepalive 60s
reverse_proxy {
to http://10.0.0.10:6081
dial_timeout 2s
keepalive 60s
