From GitHub - caddy-dns/route53: Caddy module: dns.providers.route53
(In a docker container)
/root/caddy start -config /root/Caddyfile
Port 42280 is mapped from host to container
Docker, Container is CentOS Linux release 7.8.2003. Not running under systemd.
docker run -p 42280:42280 -p 42281:42281 -p 42282:42282 --name amaranth-cow -td centos:centos7
Apps were installed after the container was created so its just that.
https://crown-amaranth-cow.dev.munvo.com:42280
reverse_proxy localhost:42283
output stdout
dns route53 {
max_retries 1
protocols tls1.2 tls1.2
We use an application called Adobe Campaign that has a client - server architecture via HTTP. I use Caddy to provide easy HTTPs for this application. The server component doesn’t come into play with this problem. Normally, Caddy works for this application, but only under the default HTTPs port.
However, when trying to connect to Caddy with https://crown-amaranth-cow.dev.munvo.com:42280
we get a wrapped error like so:
'lOB-090013 error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error (code 336032824)‘
Connecting to that host via that port works in Chrome no problem: https://crown-amaranth-cow.dev.munvo.com:42280
(behind a firewall so you’ll have to take my word).
I assumed it may have been an issue with the version of OpenSSL after identifying that the app uses OpenSSL 1.0.2n. But it seems to be related to the non-standard port and likely a misbehaving client application which is outside my control.
From other docs it seems like this might be a problem with SNI, that Caddy doesn’t know which cert to serve (working as intended).
In section 4 I will post the Wireshark excerpts, but you will see that in the SNI the application specifies the port.
Server Name: crown-amaranth-cow.dev.munvo.com:42280
I think this is a programming error on the client given that in the browser it does not specify the port in the SNI when connecting.
I don’t think the default-sni applies here as the SNI is set as you will see in the wireshark logs.
So my question: is there a way to tell Caddy to serve my https://crown-amaranth-cow.dev.munvo.com
auto tls certificate to this SNI? Or am I miss-understanding the issue perhaps.
Caddy is not emitting any details about the connection
{"level":"info","ts":1605730608.2423146,"msg":"using provided configuration","config_file":"/root/Caddyfile","config_adapter":""}
{"level":"info","ts":1605730608.247066,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1605730608.2475963,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1605730608.24809,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["crown-amaranth-cow.dev.munvo.com"]}
{"level":"info","ts":1605730608.2619185,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002f6d20"}
{"level":"info","ts":1605730608.269086,"msg":"autosaved config","file":"/root/.config/caddy/autosave.json"}
{"level":"info","ts":1605730608.269109,"msg":"serving initial configuration"}
{"level":"info","ts":1605730608.2699318,"logger":"tls","msg":"cleaned up storage units"}
Wireshark Excerpts
Client hello:
Frame 33: 408 bytes on wire (3264 bits), 408 bytes captured (3264 bits) on interface \Device\NPF_{9550F48B-2214-4F4F-A11F-226D78FC5664}, id 0
Ethernet II, Src: IntelCor_e7:56:df (48:89:e7:e7:56:df), Dst: 12:02:71:8d:cb:7f (12:02:71:8d:cb:7f)
Internet Protocol Version 4, Src: 10.88.111.35, Dst: 54.81.245.131
Transmission Control Protocol, Src Port: 60614, Dst Port: 42280, Seq: 1, Ack: 1, Len: 354
Transport Layer Security
TLSv1.2 Record Layer: Handshake Protocol: Client Hello
Content Type: Handshake (22)
Version: TLS 1.0 (0x0301)
Length: 349
Handshake Type: Client Hello (1)
Length: 345
Version: TLS 1.2 (0x0303)
Random: c9ad1928a065a6b55f888e7294820980c888a605027a7ee95b7becc8396716f2
Session ID Length: 0
Cipher Suites Length: 172
Cipher Suites (86 suites)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (0xc02c)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (0xc024)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (0xc00a)
Cipher Suite: TLS_DH_DSS_WITH_AES_256_GCM_SHA384 (0x00a5)
Cipher Suite: TLS_DHE_DSS_WITH_AES_256_GCM_SHA384 (0x00a3)
Cipher Suite: TLS_DH_RSA_WITH_AES_256_GCM_SHA384 (0x00a1)
Cipher Suite: TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 (0x009f)
Cipher Suite: TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 (0x006b)
Cipher Suite: TLS_DHE_DSS_WITH_AES_256_CBC_SHA256 (0x006a)
Cipher Suite: TLS_DH_RSA_WITH_AES_256_CBC_SHA256 (0x0069)
Cipher Suite: TLS_DH_DSS_WITH_AES_256_CBC_SHA256 (0x0068)
Cipher Suite: TLS_DHE_RSA_WITH_AES_256_CBC_SHA (0x0039)
Cipher Suite: TLS_DHE_DSS_WITH_AES_256_CBC_SHA (0x0038)
Cipher Suite: TLS_DH_RSA_WITH_AES_256_CBC_SHA (0x0037)
Cipher Suite: TLS_DH_DSS_WITH_AES_256_CBC_SHA (0x0036)
Cipher Suite: TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA (0x0088)
Cipher Suite: TLS_DHE_DSS_WITH_CAMELLIA_256_CBC_SHA (0x0087)
Cipher Suite: TLS_DH_RSA_WITH_CAMELLIA_256_CBC_SHA (0x0086)
Cipher Suite: TLS_DH_DSS_WITH_CAMELLIA_256_CBC_SHA (0x0085)
Cipher Suite: TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 (0xc032)
Cipher Suite: TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 (0xc02e)
Cipher Suite: TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 (0xc02a)
Cipher Suite: TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 (0xc026)
Cipher Suite: TLS_ECDH_RSA_WITH_AES_256_CBC_SHA (0xc00f)
Cipher Suite: TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA (0xc005)
Cipher Suite: TLS_RSA_WITH_AES_256_GCM_SHA384 (0x009d)
Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA256 (0x003d)
Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA (0x0035)
Cipher Suite: TLS_RSA_WITH_CAMELLIA_256_CBC_SHA (0x0084)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (0xc023)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (0xc009)
Cipher Suite: TLS_DH_DSS_WITH_AES_128_GCM_SHA256 (0x00a4)
Cipher Suite: TLS_DHE_DSS_WITH_AES_128_GCM_SHA256 (0x00a2)
Cipher Suite: TLS_DH_RSA_WITH_AES_128_GCM_SHA256 (0x00a0)
Cipher Suite: TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 (0x009e)
Cipher Suite: TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 (0x0067)
Cipher Suite: TLS_DHE_DSS_WITH_AES_128_CBC_SHA256 (0x0040)
Cipher Suite: TLS_DH_RSA_WITH_AES_128_CBC_SHA256 (0x003f)
Cipher Suite: TLS_DH_DSS_WITH_AES_128_CBC_SHA256 (0x003e)
Cipher Suite: TLS_DHE_RSA_WITH_AES_128_CBC_SHA (0x0033)
Cipher Suite: TLS_DHE_DSS_WITH_AES_128_CBC_SHA (0x0032)
Cipher Suite: TLS_DH_RSA_WITH_AES_128_CBC_SHA (0x0031)
Cipher Suite: TLS_DH_DSS_WITH_AES_128_CBC_SHA (0x0030)
Cipher Suite: TLS_DHE_RSA_WITH_SEED_CBC_SHA (0x009a)
Cipher Suite: TLS_DHE_DSS_WITH_SEED_CBC_SHA (0x0099)
Cipher Suite: TLS_DH_RSA_WITH_SEED_CBC_SHA (0x0098)
Cipher Suite: TLS_DH_DSS_WITH_SEED_CBC_SHA (0x0097)
Cipher Suite: TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA (0x0045)
Cipher Suite: TLS_DHE_DSS_WITH_CAMELLIA_128_CBC_SHA (0x0044)
Cipher Suite: TLS_DH_RSA_WITH_CAMELLIA_128_CBC_SHA (0x0043)
Cipher Suite: TLS_DH_DSS_WITH_CAMELLIA_128_CBC_SHA (0x0042)
Cipher Suite: TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 (0xc031)
Cipher Suite: TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02d)
Cipher Suite: TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 (0xc029)
Cipher Suite: TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 (0xc025)
Cipher Suite: TLS_ECDH_RSA_WITH_AES_128_CBC_SHA (0xc00e)
Cipher Suite: TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA (0xc004)
Cipher Suite: TLS_RSA_WITH_AES_128_GCM_SHA256 (0x009c)
Cipher Suite: TLS_RSA_WITH_AES_128_CBC_SHA256 (0x003c)
Cipher Suite: TLS_RSA_WITH_AES_128_CBC_SHA (0x002f)
Cipher Suite: TLS_RSA_WITH_SEED_CBC_SHA (0x0096)
Cipher Suite: TLS_RSA_WITH_CAMELLIA_128_CBC_SHA (0x0041)
Cipher Suite: TLS_RSA_WITH_IDEA_CBC_SHA (0x0007)
Cipher Suite: TLS_ECDHE_RSA_WITH_RC4_128_SHA (0xc011)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_RC4_128_SHA (0xc007)
Cipher Suite: TLS_ECDH_RSA_WITH_RC4_128_SHA (0xc00c)
Cipher Suite: TLS_ECDH_ECDSA_WITH_RC4_128_SHA (0xc002)
Cipher Suite: TLS_RSA_WITH_RC4_128_SHA (0x0005)
Cipher Suite: TLS_RSA_WITH_RC4_128_MD5 (0x0004)
Cipher Suite: TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA (0xc012)
Cipher Suite: TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA (0xc008)
Cipher Suite: TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA (0x0016)
Cipher Suite: TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA (0x0013)
Cipher Suite: TLS_DH_RSA_WITH_3DES_EDE_CBC_SHA (0x0010)
Cipher Suite: TLS_DH_DSS_WITH_3DES_EDE_CBC_SHA (0x000d)
Cipher Suite: TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA (0xc00d)
Cipher Suite: TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA (0xc003)
Cipher Suite: TLS_RSA_WITH_3DES_EDE_CBC_SHA (0x000a)
Cipher Suite: TLS_EMPTY_RENEGOTIATION_INFO_SCSV (0x00ff)
Compression Methods Length: 1
Compression Methods (1 method)
Extensions Length: 132
Extension: server_name (len=43)
Type: server_name (0)
Length: 43
Server Name Indication extension
Server Name list length: 41
Server Name Type: host_name (0)
Server Name length: 38
Extension: ec_point_formats (len=4)
Type: ec_point_formats (11)
Length: 4
EC point formats Length: 3
Elliptic curves point formats (3)
Extension: supported_groups (len=28)
Type: supported_groups (10)
Length: 28
Supported Groups List Length: 26
Supported Groups (13 groups)
Extension: session_ticket (len=0)
Type: session_ticket (35)
Length: 0
Data (0 bytes)
Extension: signature_algorithms (len=32)
Type: signature_algorithms (13)
Length: 32
Signature Hash Algorithms Length: 30
Signature Hash Algorithms (15 algorithms)
Extension: heartbeat (len=1)
Type: heartbeat (15)
Length: 1
Mode: Peer allowed to send requests (1)
Server Alert:
Frame 35: 61 bytes on wire (488 bits), 61 bytes captured (488 bits) on interface \Device\NPF_{9550F48B-2214-4F4F-A11F-226D78FC5664}, id 0
Ethernet II, Src: 12:02:71:8d:cb:7f (12:02:71:8d:cb:7f), Dst: IntelCor_e7:56:df (48:89:e7:e7:56:df)
Internet Protocol Version 4, Src: 54.81.245.131, Dst: 10.88.111.35
Transmission Control Protocol, Src Port: 42280, Dst Port: 60614, Seq: 1, Ack: 355, Len: 7
TLSv1.2 Record Layer: Alert (Level: Fatal, Description: Internal Error)
Content Type: Alert (21)
Length: 2
Alert Message
Level: Fatal (2)
Description: Internal Error (80)
Tried to downgrade TLS version assuming it was an issue with TLS versions.
Debugged the connection using wireshark.
Change the host port to match the caddy https port.
Works when not using a non-standard (443) port.
Works in Browsers/command line.
Tried to review the source code related to the SNI but it seems too complicated to follow.
