OpenSsl Error when accessing with https
Hi, I just installed caddy to access and trying to test it , I have a caddy file like this
:3333 {
        respond 'Thanks'
When I run without https I get correct response
curl localhost:3333 'Thanks'(env)
but when I access with https I get this error,
 curl https://localhost:3333
curl: (35) OpenSSL/3.0.13: error:0A00010B:SSL routines::wrong version number
Please help in this.
Caddy doesn’t know whether this non-standard port should be HTTP or HTTPS.
See Addresses and https_port for more details about that.
You can try:
        https_port 3333
:3333 {
        respond 'Thanks'
@ timelordx
Thank you for your response,
I modified my Caddyfile like this
https_port 3333
:3333 {
        respond 'Thanks'
but now I get this error
curl: (35) OpenSSL/3.0.13: error:0A000438:SSL routines::tlsv1 alert internal error
HTTPS needs a domain name.
And you can’t use the same port for both HTTP and HTTPS, at least not without some magic.
thanks , Mohammed90modified my config file with domain,
I get this message now
curl: (60) SSL certificate problem: unable to get local issuer certificate
how to fix it, please visit the web page mentioned above.
I checked ls /usr/local/share/ca-certificates/ but nothing present.
You will have to share your config file and the exact curl command you ran
For testing purposes, add -k to your curl command to ignore the invalid certificate. For example:
curl -kv https://localhost:3333
My config file
https_port 3333
<vps-ip>:443 {
   reverse_proxy localhost:5678 {
      flush_interval -1
<vps-ip>:3333 {
        respond 'Thanks'
command I ran:
curl https://<vps-ip>:3333
response:
curl -kv https://<vps-ip>:3333
```  works but it is insecure,
There are no public certificate providers that make certificates for ip addresses yet. Use a domain name, use it instead of the <vps-ip> in the config
