OpenSpeedTest reverse proxy poor performance
I am seeing very poor performance running the OpenSpeedTest Docker container openspeedtest/latest:v2.0.6 when Caddy is reverse proxying. If I hit the OpenSpeedTest Docker container directly without Caddy in-front I get the full expected 1Gbps up and down. Any performance directives I should be looking at?
htop shows barely any cpu or load, so does not indicate a system resource issue.
apt get install caddy then override the default caddy binary in /usr/bin with a custom built caddy binary that includes cloudflare support.
Debian GNU/Linux 12 (bookworm)
    email justin@mydomain.com
speedtest.mydomain.com {
    reverse_proxy 172.18.0.3:3000
        dns cloudflare {env.CF_API_KEY}
Performance is subjective, and poor performance could be for variety of reasons. To help understand the root cause, please pull the profile per the instructions here.
