In my http://www.domain.com, Only login and register need redir to https ,like this:
http://www.domain.com/login, http://www.domain.com/register redir to https:
how to setup in Caddyfile ?
Hi @goodforever,
Honestly, it’s probably simpler just to have the whole site on HTTPS. It certainly won’t hurt. Caddy can definitely do what you’re asking, though.
You can use if statements with redir. You’ll want to compare the {path} placeholder to the locations you want to redirect. You’ll also need to change if_op if you’ve got multiple locations - by default, it’s AND, you want OR.
redir {
if_op or
if {path} starts_with /login
if {path} starts_with /register
/ https://example.com{uri}
https://caddyserver.com/docs/redir
https://caddyserver.com/docs/placeholders
Thanks, Is it like the following ?
https://www.mydomain.com {
gzip
tls username@mydomain.com
proxy / http://myservice:8080
http://www.mydomain.com {
redir {
if_op or
if {http://www.mydomain.com/login} starts_with /login
if {http://www.mydomain.com/register} starts_with /register
/ https://www.mydomain.com{uri}
gzip
The if statements look incorrect - the URL doesn’t go there, the placeholder does. Check the placeholders docs again - the one you want is {path}, used like: if {path} starts_with ...
Looks good otherwise!
{path} , Thanks!
