Hi,
I have two IP addresses on the same dedicated server. I was wondering if there is an advantage or inconvenient to run one instance of Caddy per IP ?
Thank you,
Hi,
Thank you,
Generally you should only one run Caddy instance per machine. You can tell Caddy to bind certain sites to certain interfaces with the bind directive.
Thank you for your reply.
I didn’t know if it would improve performances or not.
By the way, I am taking the opportunity to congratulate you and your community, I hope Caddy and your other projects will have a bright future. (I hope this is the right expression in English
Yes it is, thank you!
It’s not a matter of performance. Two Caddy instances on the same machine would not work well when obtaining TLS certificates from Let’s Encrypt because they’d share the same storage.
I admit, for small sites it doesn’t matter much: If you have a network card which supports more than one queue for incoming packets (good cards have at least 4 Tx and 4 Rx queues; even cheap ones have 2 Rx, 2Tx these days) and »disperse« them across several interrupts (for better performance on NUMA or/and multi-core machines), iff and then it’s beneficial to start more than one process, because Go is not very good when it comes to thread/core/IRQ pinning.
Thank you for your comments.
