Using the latest caddy version from the Ubuntu PPA, are the only ways to support www and non www at the same time (For the same caddyfile domain entry) mean I would have to do the following or is there another way:
Thank you Francis, so it is how I understood it. What about saying that you want multiple subdomains pointing to the same place. For example would *.example.com work? to tell it all subdomains or any non existing sub domain to point it to the same place. How can I specify all subdomains except X one where it would be pointing to another place. I will assume I would add the X subdomain below the setup for the *.example.com yes?
