On Demand TLS with custom CA and nested Wildcards
My organisation has automatic DNS records that point to developer machines so they can use real devices to access their local development environment. This setup should use TLS like everything else. Since we also develop different applications it is a challenge to use wildcard certificates.
Basically we have hundreds of permutations like this:
ahost.computer001.swe.test
bhost.computer001.swe.test
chost.computer002.swe.test
ahost.computer003.swe.test
bhost.computer003.swe.test
My goal is to deploy Caddy to each development machine and use it to issue certificates on demand signed by our own Intermediate CA that is trusted in the entire organisation.
I was unable to make it work with ahost.*.swe.test site blocks. Using a single :443 block and utilizing the host matcher does work.
But I’m unsure if this is a legitimate approach or if I’m getting myself into trouble further down the line?
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4149845,"logger":"events","msg":"event","name":"tls_get_certificate","id":"11803697-45c7-40d3-a70e-32e680702ecd","origin":"tls","data":{"client_hello":{"CipherSuites":[6682,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"ahost.lse015.swe.test","SupportedCurves":[23130,4588,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[39578,772,771],"RemoteAddr":{"IP":"172.28.96.1","Port":63433,"Zone":""},"LocalAddr":{"IP":"172.28.97.131","Port":443,"Zone":""}}}}
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4150639,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"ahost.lse015.swe.test"}
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4150696,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.lse015.swe.test"}
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4150717,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.swe.test"}
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4150765,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.test"}
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4150784,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.*"}
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4150884,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"172.28.96.1","remote_port":"63433","server_name":"ahost.lse015.swe.test","remote":"172.28.96.1:63433","identifier":"ahost.lse015.swe.test","cipher_suites":[6682,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
Apr 29 14:11:55 LSE015 caddy[3754]: {"level":"debug","ts":1777464715.4151363,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.28.96.1:63433: no certificate available for 'ahost.lse015.swe.test'"}
caddy --version
v2.11.2 h1:iOlpsSiSKqEW+SIXrcZsZ/NO74SzB/ycqqvAIEfIm64=
Debian 13 inside WSL running on a Windows 11 Host.
sudo systemctl start caddy
sudo systemctl cat caddy
# /usr/lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
d. My complete BROKEN Caddy config:
        pki {
                ca lan_ca {
                        name lan_ca
                        root {
                               format pem_file
                               cert /etc/caddy/ca.crt
                        intermediate {
                               format pem_file
                               cert /etc/caddy/swe-test-intermediate.crt
                               key /etc/caddy/swe-test-intermediate.key
        on_demand_tls {
                ask http://localhost:2019/ask
        cert_issuer internal {
                ca lan_ca
:2019 {
    handle_path /ask {
        @allowed expression {query.domain}.endsWith(".swe.test")
        respond @allowed 200
        respond 403
ahost.*.swe.test {
                on_demand
        respond "https on ahost"
bhost.*.swe.test {
                on_demand
        respond "https on bhost"
e. My complete WORKING Caddy config:
        pki {
                ca lan_ca {
                        name lan_ca
                        root {
                               format pem_file
                        intermediate {
                               format pem_file
        on_demand_tls {
                ca lan_ca
:2019 {
    handle_path /ask {
        respond 403
:443 {
                on_demand
        @ahost host ahost.*.swe.test
        @bhost host bhost.*.swe.test
        handle @ahost {
        handle @bhost {
I think your approach is fine :+1: – other than using :2019, which is the admin socket (well technically the admin socket is localhost:2019. You might run into issues there.
The restriction is the way it is in site block addresses because of rules for TLS certificates, but I think your config is fine.
Thank you for the answer and building Caddy in the first place :slight_smile:
