I tried to use the on demand tls from my old config which works for Caddy 2.6.4 into Caddy 2.7.4
Docker version.
INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000432e00"}
INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
WARN pki.ca.local installing root certificate (you might be prompted for password) {"path": "storage:pki/authorities/local/root.crt"}
INFO warning: "certutil" is not available, install "certutil" with "apt install libnss3-tools" or "yum install nss-tools" and try again
INFO define JAVA_HOME environment variable to use the Java trust
INFO certificate installed properly in linux trusts
INFO http enabling HTTP/3 listener {"addr": ":8282"}
INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details.
INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
INFO autosaved config (load with --resume flag) {"file": "/config/caddy/autosave.json"}
INFO serving initial configuration
INFO tls cleaning storage unit {"description": "FileStorage:/data/caddy"}
INFO tls finished cleaning storage units
Version 2.7.4 Docker with:
Build using xcaddy builder
OS: Debian 11
use UI Portainer to change the Docker image from old caddy 2.6.4 to 2.7.4
on_demand_tls {
interval 2m
burst 5
https://:8282 {
@get method GET
route {
basicauth {
user passhere
file_server @get browse {
root /
issuer internal
on_demand
