caddy_windows_amd64_custom.exe run
Windows 10
on_demand_tls {
ask http://localhost:3000/caddy/allowed-domain
https:// {
on_demand
# Proxy to the main server
reverse_proxy / http://127.0.0.1:3000 {
# Add headers any proxy would expect
header_up X-Real-IP {remote}
header_up X-Forwarded-For {remote}
header_up X-Forwarded-Port {server_port}
# We should never take more than 5s to load
health_timeout 5s
https://*.discordpage.com {
tls security@obelous.com {
dns cloudflare MY_CLOUDFLARE_TOKEN
# Confirm the request came from our Caddy proxy
#header_upstream PageHost {host}
health_timeout 5s
I am using on_demand tls for my customers however, my “ask” endpoint takes around 10 seconds to complete, which causes caddy to do absolutely nothing (not even any messages about it trying to issue certs, failing challenges, nothing)
However upon changing my endpoint to return 200 instantly, on_demand tls functions just fine.
C:\Users\Casper\Pictures\UbisoftConnect>caddy_windows_amd64_custom.exe run
2022/01/10 01:46:04.983 ←[34mINFO←[0m using adjacent Caddyfile
2022/01/10 01:46:04.985 ←[33mWARN←[0m input is not formatted with 'caddy fmt' {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2022/01/10 01:46:04.994 ←[34mINFO←[0m admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["[::1]:2019", "127.0.0.1:2019", "localhost:2019"]}
2022/01/10 01:46:04.994 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc00037a4d0"}
2022/01/10 01:46:04.995 ←[34mINFO←[0m http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2022/01/10 01:46:04.997 ←[34mINFO←[0m tls cleaning storage unit {"description": "FileStorage:C:\\Users\\Casper\\AppData\\Roaming\\Caddy"}
2022/01/10 01:46:04.998 ←[34mINFO←[0m http enabling automatic TLS certificate management {"domains": ["*.discordpage.com"]}
2022/01/10 01:46:05.002 ←[34mINFO←[0m autosaved config (load with --resume flag) {"file": "C:\\Users\\Casper\\AppData\\Roaming\\Caddy\\autosave.json"}
2022/01/10 01:46:05.002 ←[34mINFO←[0m serving initial configuration
2022/01/10 01:46:05.002 ←[34mINFO←[0m tls finished cleaning storage units
N/A
