I have ask
setup and working nicely, but my logs show something I think is not quite right.
{"level":"error","ts":1725036521.1167374,"logger":"tls.obtain","msg":"will retry","error":"[172.21.0.2] Obtain: subject does not qualify for a public certificate: 172.21.0.2","attempt":2,"retrying_in":120,"elapsed":60.005017771,"max_duration":2592000}
{"level":"info","ts":1725036641.1100104,"logger":"tls.obtain","msg":"releasing lock","identifier":"172.21.0.2"}
Alpine Linux. Docker compose. Caddyfile.
See C.
version: "3.9"
image: caddy:alpine
- 80:80
- 443:443
- 443:443/udp
- ./volumes/caddy/config:/config/caddy
- ./volumes/caddy/data:/data/caddy
working_dir: /srv/www
# Variables that get imported
# Secret public domain verification
(import_ask) {
on_demand_tls {
ask http://REDACTED/check
# Common configuration
(import_common) {
# Reverse Proxy
(import_reverse_proxy) {
reverse_proxy {
to http://REDACTED
# TLS
(import_tls) {
on_demand
# Headers
(import_headers) {
# Passive Headers
?Cache-Control max-age=3600
# Normal Headers
# X
X-Jjj https://jjj.software
X-Download-Options noopen
X-Environment Production
X-Frame-Options SAMEORIGIN
X-SSL-Domain {host}
X-XSS-Protection 1; mode=block
# CSRF
Access-Control-Allow-Origin *
#Strict-Transport-Security max-age=31536000; includeSubDomains; preload
# Permissions
Permissions-Policy interest-cohort=()
# CSP
Content-Security-Policy "default-src 'self'; connect-src 'self' https:; style-src 'self' 'unsafe-inline' data: https:; script-src 'self' 'unsafe-eval' 'unsafe-inline' https:; font-src 'self' data: https:; img-src 'self' blob: data: https: http:; media-src 'self' blob: data: https:; frame-src 'self' blob: https:; frame-ancestors 'self' blob: https:; object-src 'self'; worker-src 'self' blob: https:"
# Definitions
# Global
email admin@jjj.domains
import import_ask
# Checker
http:// {
handle /check {
import import_reverse_proxy
# App
:443 {
import import_tls
import import_headers
The Caddy docs state:
hostnames qualify for publicly-trusted certificates if they … are not an IP address
I interpreted this to mean that IPs (like the Docker network IPs) would not qualify for public certificates, which clearly Caddy is seeing & logging.
I am guessing that one of the server blocks is overriding the default IP omission? If so, what is the syntax to exclude/skip/prevent these Docker IPs (or really any IP/non-FQDM) from being included in the on-demand?
