Odd behaviour in Websocket - not sure where to begin looking
I have installed Tactical RMM behind Caddy. Everything is working as expected with one exception; when attempting to upload files via the file browser in MeshCentral. Larger file (over 1K) do not complete.
I have remove Caddy by pointing clients directly at the RMM/MeshCentral server and the upload completes normally.
Looking at the message within the websocket, I see “action”:“uploadstart”, followed by “action”:“uploaddone”.
On a failing upload, I see the start, then 1 or more “action”:“uploadack” but never get an uploaddone. The socket is still live and ping/pongs continue normally.
There are no errors reported.
I added the via the cloudsmith.io REPO.
Ubuntu 22.04.4 LTS
systemd 249 (249.11-0ubuntu3.12)
	#debug
	log default {
		output file /var/log/caddy/caddy.log {
			roll_size 10
		include http.log.access admin.api
example.com {
	root * /var/www/caddy
# Proxmox
pve.example.com {
	reverse_proxy https://192.168.1.43:8006 {
			tls_insecure_skip_verify
# Remotely
remotely.example.com {
	reverse_proxy http://10.40.3.13:5000
# Linkwarden
bookmark.example.com {
	reverse_proxy http://10.40.3.51:3000
# Tactical RMM
(trmmcert) {
	tls /etc/caddy/example.com/fullchain1.pem /etc/caddy/example.com/privkey1.pem
rmm.example.com {
	import trmmcert
	reverse_proxy /.well-known/acme-challenge/* http://10.40.3.20:2080
	reverse_proxy https://10.40.3.20:443 {
api.example.com {
	import trmmcert
mesh.example.com {
	import trmmcert
	log
# Mattermost
https://mattermost.example.com {
	reverse_proxy https:/10.40.3.21:8065 {
			tls
The certs used for (trmmcert) are valid LetsEncrypt issued certs.
https://meshcentral.com/
I don’t have any suggestion as to how to debug this. I don’t know how this upload is operating. Probably best if the authors of the upstream app you’re proxying to tries to replicate the issue, since they’ll be able to debug what the application is seeing.
Thanks. I appreciate your response.
I am checking with meshcentral also. I guess I wanted to confirm there were no silly errors or oversights in my setup.
