Nothing happens after tls.issuance.acme.acme_client trying to solve challenge
I’m trying to use GitHub - caddy-dns/route53: Caddy module: dns.providers.route53 to get the certificate from let’s encrypt for servers that are served in an internal network (not accessible outside).
Unfortunately, it seems to get stuck when trying to solve the DNS challenge
2024/10/27 13:48:54.435 INFO  tls.cache.maintenance started background certificate maintenance  {"cache": "0xc000259500"}
2024/10/27 13:48:54.435 WARN  http.auto_https server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv1", "http_port": 80}
2024/10/27 13:48:54.436 INFO  http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/10/27 13:48:54.436 INFO  http.auto_https enabling automatic HTTP->HTTPS redirects  {"server_name": "srv0"}
2024/10/27 13:48:54.436 DEBUG http.auto_https adjusted config {"tls": {"automation":{"policies":[{"subjects":["home.intern.agiletomato.com"]},{}]}}, "http": {"servers":{"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"192.168.122.202:8123"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv1":{"listen":[":80"],"routes":[{},{"handle":[{"handler":"vars","root":"/usr/share/caddy"},{"handler":"file_server","hide":["/etc/caddy/Caddyfile"]}]},{}],"automatic_https":{"disable":true}}}}}
2024/10/27 13:48:54.436 INFO  tls.cache.maintenance stopped background certificate maintenance  {"cache": "0xc000259500"}
2024/10/27 13:48:54.737 INFO  admin admin endpoint started  {"address": "unix//run/caddy/admin.socket", "enforce_origin": false, "origins": ["", "//127.0.0.1", "//::1"]}
2024/10/27 13:48:54.738 INFO  tls.cache.maintenance started background certificate maintenance  {"cache": "0xc0003de480"}
2024/10/27 13:48:54.738 INFO  http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/10/27 13:48:54.738 INFO  http.auto_https enabling automatic HTTP->HTTPS redirects  {"server_name": "srv0"}
2024/10/27 13:48:54.738 WARN  http.auto_https server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv1", "http_port": 80}
2024/10/27 13:48:54.738 DEBUG http.auto_https adjusted config {"tls": {"automation":{"policies":[{"subjects":["home.intern.agiletomato.com"]},{}]}}, "http": {"servers":{"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"192.168.122.202:8123"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv1":{"listen":[":80"],"routes":[{},{"handle":[{"handler":"vars","root":"/usr/share/caddy"},{"handler":"file_server","hide":["/etc/caddy/Caddyfile"]}]},{}],"automatic_https":{"disable":true}}}}}
2024/10/27 13:48:54.739 DEBUG http  starting server loop  {"address": "[::]:80", "tls": false, "http3": false}
2024/10/27 13:48:54.739 INFO  http.log  server running  {"name": "srv1", "protocols": ["h1", "h2", "h3"]}
2024/10/27 13:48:54.739 INFO  http  enabling HTTP/3 listener  {"addr": ":443"}
2024/10/27 13:48:54.739 DEBUG http  starting server loop  {"address": "[::]:443", "tls": true, "http3": true}
2024/10/27 13:48:54.740 INFO  http.log  server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/10/27 13:48:54.740 INFO  http  enabling automatic TLS certificate management {"domains": ["home.intern.agiletomato.com"]}
2024/10/27 13:48:54.740 ERROR unable to autosave config {"file": "/etc/caddy/autosave.json", "error": "open /etc/caddy/autosave.json: read-only file system"}
2024/10/27 13:48:54.740 INFO  serving initial configuration
2024/10/27 13:48:54.741 INFO  tls.obtain  acquiring lock  {"identifier": "home.intern.agiletomato.com"}
2024/10/27 13:48:54.746 INFO  tls storage cleaning happened too recently; skipping for now  {"storage": "FileStorage:/var/lib/caddy", "instance": "1b227ed4-1825-4a12-966b-872eaaeedc58", "try_again": "2024/10/28 13:48:54.746", "try_again_in": 86399.999998916}
2024/10/27 13:48:54.746 INFO  tls finished cleaning storage units
2024/10/27 13:48:54.748 INFO  tls.obtain  lock acquired {"identifier": "home.intern.agiletomato.com"}
2024/10/27 13:48:54.748 INFO  tls.obtain  obtaining certificate {"identifier": "home.intern.agiletomato.com"}
2024/10/27 13:48:54.748 DEBUG events  event {"name": "cert_obtaining", "id": "cc3ffaa8-3a5b-4704-abb7-96da081d1d7f", "origin": "tls", "data": {"identifier":"home.intern.agiletomato.com"}}
2024/10/27 13:48:54.749 DEBUG tls.obtain  trying issuer 1/1 {"issuer": "acme-v02.api.letsencrypt.org-directory"}
2024/10/27 13:48:54.750 INFO  tls.issuance.acme waiting on internal rate limiter  {"identifiers": ["home.intern.agiletomato.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/10/27 13:48:54.750 INFO  tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["home.intern.agiletomato.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/10/27 13:48:54.750 INFO  tls.issuance.acme using ACME account  {"account_id": "https://acme-v02.api.letsencrypt.org/acme/acct/2023152457", "account_contact": []}
2024/10/27 13:48:55.332 DEBUG tls.issuance.acme.acme_client http request  {"method": "GET", "url": "https://acme-v02.api.letsencrypt.org/directory", "headers": {"User-Agent":["Caddy/2.8.4 CertMagic acmez (linux; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["746"],"Content-Type":["application/json"],"Date":["Sun, 27 Oct 2024 13:48:55 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/10/27 13:48:55.333 DEBUG tls.issuance.acme.acme_client creating order  {"account": "https://acme-v02.api.letsencrypt.org/acme/acct/2023152457", "identifiers": ["home.intern.agiletomato.com"]}
2024/10/27 13:48:55.521 DEBUG tls.issuance.acme.acme_client http request  {"method": "HEAD", "url": "https://acme-v02.api.letsencrypt.org/acme/new-nonce", "headers": {"User-Agent":["Caddy/2.8.4 CertMagic acmez (linux; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sun, 27 Oct 2024 13:48:55 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["XM4ukI6HU3Ommrn9q0a_yT3U2DiWr5gkBlFj7z-Ih9k1j5EL5lw"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/10/27 13:48:55.829 DEBUG tls.issuance.acme.acme_client http request  {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/new-order", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.4 CertMagic acmez (linux; amd64)"]}, "response_headers": {"Boulder-Requester":["2023152457"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["353"],"Content-Type":["application/json"],"Date":["Sun, 27 Oct 2024 13:48:55 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/2023152457/317529898907"],"Replay-Nonce":["XM4ukI6H6NtkEyDHWp4Tcq0NnLETWQ0RCv-NuaGgHkovEHdOY6A"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 201}
2024/10/27 13:48:56.025 DEBUG tls.issuance.acme.acme_client http request  {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/421919347487", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.4 CertMagic acmez (linux; amd64)"]}, "response_headers": {"Boulder-Requester":["2023152457"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["811"],"Content-Type":["application/json"],"Date":["Sun, 27 Oct 2024 13:48:55 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["XM4ukI6HbGnt6hq05f5UmJ4TkNeG3HjrWlZsb8RKL0ZqzZfhUSs"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/10/27 13:48:56.026 INFO  tls.issuance.acme.acme_client trying to solve challenge {"identifier": "home.intern.agiletomato.com", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
I’ve installed caddy with xcaddy --with github.com/caddy-dns/route53
caddy version
I installed caddy with pacman -Sy caddy
I then used xcaddy to build a new binary with xcaddy --with github.com/caddy-dns/route53 and replaced /usr/bin/caddy with the newly built binary
EndeavourOS
sudo systemctl enable caddy
The unit file used was installed by pacman -Sy caddy
# /usr/lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Description=Caddy web server
After=network-online.target
Wants=network-online.target
StartLimitIntervalSec=14400
StartLimitBurst=10
Type=notify
Environment=XDG_DATA_HOME=/var/lib
Environment=XDG_CONFIG_HOME=/etc
ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile
ExecStopPost=/usr/bin/rm -f /run/caddy/admin.socket
# Do not allow the process to be restarted in a tight loop. If the
# process fails to start, something critical needs to be fixed.
Restart=on-abnormal
# Use graceful shutdown with a reasonable timeout
# Hardening options
DevicePolicy=closed
LockPersonality=true
MemoryAccounting=true
MemoryDenyWriteExecute=true
NoNewPrivileges=true
PrivateDevices=true
ProcSubset=pid
ProtectClock=true
ProtectControlGroups=true
ProtectHome=true
ProtectHostname=true
ProtectKernelLogs=true
ProtectKernelModules=true
ProtectKernelTunables=true
ProtectProc=invisible
ProtectSystem=strict
RemoveIPC=true
ReadWritePaths=/var/lib/caddy /var/log/caddy /run/caddy
RestrictNamespaces=true
RestrictRealtime=true
RestrictSUIDSGID=true
First file /etc/caddy/CaddyFile
	# Restrict the admin interface to a local unix file socket whose directory
	# is restricted to caddy:caddy. By default the TCP socket allows arbitrary
	# modification for any process and user that has access to the local
	# interface. If admin over TCP is turned on one should make sure
	# implications are well understood.
	admin "unix//run/caddy/admin.socket"
		output file /var/log/caddy/caddy.log
		format console
		level DEBUG
http:// {
	root * /usr/share/caddy
	# php_fastcgi localhost:9000
	# Refer to the directive documentation for more options.
	# https://caddyserver.com/docs/caddyfile/directives
# Import additional caddy config files in /etc/caddy/conf.d/
import /etc/caddy/conf.d/*
Second file /etc/caddy/conf.d/home
home.intern.agiletomato.com {
    dns route53 {
                max_retries 10 # optional
                profile "default"
                access_key_id "AKI....." # required if $AWS_ACCESS_KEY
                secret_access_key "Zj....." # required if $AWS_SECRET_ACCESS_KEY is not defined
                region "us-east-1" # required if $AWS_REGION is not defined
                max_wait_dur 60, # propagation wait duration in seconds (optional)
                wait_for_propagation false # wait for records to propagate (optional)
  reverse_proxy 192.168.122.202:8123
5. Additional attempts
I’ve tried running caddy run --config /etc/caddy/CaddyFile
2024/10/27 15:25:56.510	INFO	using config from file	{"file": "/etc/caddy/Caddyfile"}
2024/10/27 15:25:56.514	INFO	adapted config to JSON	{"adapter": "caddyfile"}
2024/10/27 15:25:56.515	INFO	redirected default logger	{"from": "stderr", "to": "/var/log/caddy/caddy.log"}
2024/10/27 15:25:58.676	INFO	route53: unable to load AWS SDK config, failed to get shared config profile, default
Hi there!
I don’t personally use this plugin. I took a look at an old post about Route 53 issues (totally unrelated to your issue) but I noticed that their configuration doesn’t include the profile line.
I suggest you remove the profile line unless you’re using an AWS shared credentials file (which it looks like you aren’t).
    dns route53 {
                **# profile "default"**
Your error message also makes me think the profile line is the cause:
route53: unable to load AWS SDK config, failed to get shared config profile, default as it specifically references the “default” profile.
Yes, that was exactly the issue… Was coming back to mark my error as solved when I saw your message :slight_smile:
What threw me off was that that route53 error didn’t appear in the logs.
